Super-Ram or Miniram intake on LT1??
Old Jan 31, 2006 | 03:51 PM
FastZinTennessee's Avatar
I ran across a web page while searching around that had dyno tests of various SBC setups. The page can be found here-
http://www.geocities.com/MotorCity/7610/dyno.htm
I noticed they were using Super-Ram or Miniram intakes on the LTX motors that were tested. This caught my attention because I haven't seen or heard of anyone on here doing this (if anyone is it must have just slipped by).
I know that the Super-Ram is not cheap, and I'm assuming that the Miniram is not either, but what kind of advantages would doing this have, if any? Do the intakes in question have the ability to perform better at high RPM? If these intakes are worthwhile I might consider trying to find a used setup since the intake is cake to swap out compared to everything else on this car!
Old Jan 31, 2006 | 04:03 PM
96m6lt1's Avatar
Re: Super-Ram or Miniram intake on LT1??
i have seen quite a few modded lt1s using the superram however they were mostly on impalas
Old Jan 31, 2006 | 04:06 PM
SStrokerAce's Avatar
Miniram is basically a LT1 intake.
Old Jan 31, 2006 | 04:47 PM
Aha, I haven't seen a picture of a Miniram. I have seen the Super-Ram though, and it's quite a bit different- would it show any significant gains?
Old Jan 31, 2006 | 05:29 PM
Kevin Blown 95 TA's Avatar
According to Lingenfelter, they help torque quite a bit on an A4 car and not near as much on a M6 car. However, for a 4th gen F-Body, he had to shorten the height of the plenum which didn't help it any. These type intakes are supposed to help even distribution of air flow through the manifold. If you get one with a cast alum top, they don't seal well, and a billet top is the best way to go.
Old Jan 31, 2006 | 07:12 PM
MEAN LT1's Avatar
No talk about intakes until you fix your car. Then talk about all the intakes in the world. I want this car done by friday Young man.
Old Jan 31, 2006 | 07:20 PM
Ok, ok, ok! Cross your fingers that the coil is my only problem and with a little luck it will be running Thursday
oldschool
Feb 9, 2016 09:21 PM
onefastgta
Mar 19, 2015 10:10 AM
formula218
Dec 2, 2014 04:27 PM
thenewkid
Nov 27, 2014 09:41 AM
Jul 4, 2005 05:00 PM
