Super hard to start running real rich
Old Nov 1, 2006 | 07:03 AM
1994lt1z28's Avatar
Hey got a little problem that has cost big bucks need help.
car is 94 z28 been running real rich but would start on first
crank a week ago it got super hard to start like 4 or 5 min
of cranking with foot on floor if left for like 2 hours car has
bbk headers 3'' flowmaster exhaust k&n cold air kit full msd
ignition: wires cap rotor coil opti and 6al box tpis airfoil
160 thermo 150 shot of dynotune nos great kit by the way
1.6 roller rockers hurst short throw shifter. seems to be
flooding out when it does finally start big cloud of dark smoke
this is first fuel injected car so new to the computer stuff
any help would be great
Old Nov 1, 2006 | 07:43 AM
93transam1234's Avatar
Most likely you fould your plugs from running rich.
Try just replacing the drivers side(because those are easy) and se if it fires up better. If it does then replace the other half.
YOu also need find out why you are running so rich or you are going to do more damage then just fouling your plugs...if you havnt all ready
Old Nov 1, 2006 | 08:13 AM
Hard start, and then running excessively rich may be related to a failed coolant temp sensor. Is the SES light on? Do you have access to a scanner to look at the sensors and other engine operating parameters through the PCM?
Old Nov 1, 2006 | 08:57 AM
1994lt1z28's Avatar
no ses light guy at parts house thinks fuel pressure reg is bad or stuck injector orderd fpr be in friday see what happens just changed plugs no difference
Old Nov 1, 2006 | 09:51 AM
Why not measure the fuel pressure with a gauge before spending money on a fuel pressure regulator?
Old Nov 1, 2006 | 10:10 AM
Sweetred95ta's Avatar
Why would you just start buying parts and throwing them at the car?? You do know that you can check your fuel pressure with a gauge, don't you? There's no sense in us trying to help if you're not going to diagnose the problems before you randomly purchase parts based on what the local part store guy thinks. BTW, punctuation is a good thing.
Edit: Injuneer beat me to it. I had the window open for a while and didn't refresh.
Old Nov 1, 2006 | 11:23 AM
1994lt1z28's Avatar
I'll do that thank you.
Old Nov 1, 2006 | 01:07 PM
hulettsz28's Avatar
This happened to me and it was the coolant sensor on the front of the motor. It would crank and crank and finally turn over, then you could smell the fuel when it WAS running. It wound up flooding my crank case with fuel and my oil smelled like 93 octane. I would definately not drive it very long without making sure it isnt that coolant sensor and smelling/checking your oil to make sure there is no fuel in it.
Old Nov 1, 2006 | 02:31 PM
1994lt1z28's Avatar
The one on the water pump?
Old Nov 1, 2006 | 02:41 PM
95LT1conv's Avatar
yes
Old Nov 1, 2006 | 03:23 PM
95LT1conv's Avatar
did you get my pm?
Old Nov 2, 2006 | 01:25 AM
1994lt1z28's Avatar
yes i will try it in morning
Old Nov 2, 2006 | 03:15 PM
1994lt1z28's Avatar
installed coolant sensor no change. pulled vac line on fpr smelled fuel so will
change that tomorrow and hope for the best
also got a guy that is trying to sell me ls1 24# injectors says they are better
than stock ones he only wants $50
Old Nov 2, 2006 | 05:02 PM
Do you realize its very simple to test things like the coolant temp sensor, rather than running out and buying a new one, and finding out that it wasn't the problem?
Did you check the fuel pressure with a guage? That would confirm the suspicions your "smell test" generated?
LS1 fuel injectors are typically rated at higher than 24#/HR, unless he it giving you the "derated" flow capacity, based on the fact that the LS1 injectors are flow rated at a higher pressure (58psi) than the LT1 injectors (43.5psi).
Old Nov 2, 2006 | 07:29 PM
1994lt1z28's Avatar
Thanks for the info what am I looking for the fuel pressure guage to do?
o and i don't mind replacing a 5.00 sensor for saftey sake. The opti needed
to be replaced before I got the car and it fixed the surging above 4k
not being snotty but little things like 5.00 sensors and a 8.00 tps is just good
precaution.
