Summit X pipe question
Old Jun 13, 2005 | 06:35 PM
Black6spdZ's Avatar
For those of you that have a summit x pipe did you get the kit with the other pipes or just the x itself. If the other 4 pipes arent going to be close enough to make work than i will just order the x itself. but i like the mandrel bends of the kit. any input is appreciated
Old Jun 13, 2005 | 07:54 PM
simple's Avatar
Re: Summit X pipe question
i bought the $100 3" "summit x-pipe kit" (4 mandrel bent legs and x-pipe)
had too purchase collector reducers (3"-3")
bolted up too my Hookers like it was meant too be there
EDIT: i did pull the trans cross member and grind about 4" off of the lip for clearance...did i have too, i dont know but i did it anyway so i didnt have too pull it later
Old Jun 13, 2005 | 08:48 PM
94 TA TT2S's Avatar
Same here.....Worked like a charm......I had it on there once with the x-pipe like you would normally put it and it worked awesome with stock Torque arm, I changed to Spohn TA and just turned the x around and it went around the ta that way....
DirtyDaveW
Dec 1, 2016 05:37 PM
linz
3rd Gen / L98 Engine Tech
Oct 22, 2015 07:59 AM
Queens94z28
Dec 20, 2014 09:11 PM
Elcojoe
Nov 17, 2014 10:27 PM
CobraEatr
Jul 24, 2004 11:37 AM
