Summit Optispark II?
Old Apr 13, 2006 | 09:33 AM
96TurboTA's Avatar
Has anyone noticed summit selling the "Optispark II". I just noticed it today.
http://store.summitracing.com/partde...5&autoview=sku
Old Apr 13, 2006 | 01:05 PM
Rob WS6's Avatar
Re: Summit Optispark II?
By II they mean vented... look at the application chart, only vented opti cars listed.
Old Apr 13, 2006 | 01:11 PM
Z28SORR's Avatar
From the WEB site:
New ignition for your LT1.
Replace your stock LT1 Optispark II distributor with our all-new Summit LT1 Optispark II distributors. These distributors feature an aluminum housing with heavy-duty oilite bushings, and a glass-reinforced cap with high dielectric strength and brass terminals.
This discription infers there are some small differences.
Old Apr 13, 2006 | 01:16 PM
Honda Hunter's Avatar
The discription sounds exactly like what Accel's says. Why is everyone just now starting to make opti's but dont have them in stock?
Old Apr 13, 2006 | 02:29 PM
Mike96z's Avatar
Best Opti on the market right now is the Pro-Billet LT1 MSD. MSD-8381 (non-vented) MSD-83811 (vented) $499.88 ea.
Discription:
MSD's hot Pro-Billet LT1 distributor is designed to replace the GM Optispark unit. It features an advanced optical encoder matched to a rugged billet body with an extra cap bolt to eliminate leaks, a drive assembly indexed to the shaft so it can't slip, and a hefty ball-bearing support assembly good to 10,000 rpm. A clever mechanism allows you to vary timing +/- 5 degrees and the distributor is topped by a heavy-duty cap with brass terminals. Mounting hardware included.
Old Apr 13, 2006 | 02:59 PM
How is that the best when nobody has it? I'll stick with my over rated Dynaspark.
Old Apr 13, 2006 | 03:13 PM
96TurboTA's Avatar
Then why do they list part numbers for the vented, non-vented, and the "optispark II"
Old Apr 13, 2006 | 03:28 PM
cndctrdj's Avatar
so how many options are there out for the lt1 now
Old Apr 13, 2006 | 03:38 PM
96TurboTA's Avatar
Genuine GM vented and non-vented optisparks, dynaspark, The Accel optispark II, and the summit optispark II. MSD is supposedly coming out this summer, but who really knows. Then there are the LTCC, and Delteq coil conversions using the optical side of the opti.
Old Apr 13, 2006 | 03:39 PM
cndctrdj's Avatar
will the msd be worth the wait, i have the time, but will it be worth it
Old Apr 13, 2006 | 03:50 PM
96TurboTA's Avatar
That is the big question. I don't think I can wait that long.
Old Apr 13, 2006 | 04:13 PM
30AnvZ28's Avatar
the stock ones arent that bad. they last on average 100,000 miles. Thats just fine in my book. I got 140K out of my original one, and I purchased a GM one for my new 383 going in this weekend.
Old Apr 13, 2006 | 06:11 PM
guywithaZ's Avatar
I got 50k before mine fell apart...
Old Apr 13, 2006 | 06:17 PM
2000GTP's Avatar
Originally Posted by Z28SORR
From the WEB site:
I wonder if this is just fancy marketing terminology or if these distributors will actually perform as advertised.
Old Apr 14, 2006 | 11:47 AM
cndctrdj's Avatar
i have till september before i need to send my motor out
so maybee it will be done maybee it wont
