Summit electric water pump?
Old May 1, 2008 | 10:52 PM
GreasyB's Avatar
Have any of you used the summit brand electric water pump? If so how was fitment and did it work out fine? Or if you would sugest another brand that would be good too. Please tell about fitment and reliability though. Price is a factor also.
Old May 2, 2008 | 04:07 AM
tapout911's Avatar
Im running the summitt pump. Its been on there for awhile with no trouble at all. Fitment is great
Old May 2, 2008 | 09:11 AM
rickyzZ28's Avatar
A guy I put the motor together for is running one and it is a little taller than the CSR that used to be on the car, which required a little trimming of the fan shroud, but other than that it is great.
Old May 2, 2008 | 10:29 PM
GreasyB's Avatar
Sounds like that is the one I will probly get. Thanks guys.
Old May 3, 2008 | 02:31 AM
GASH1313's Avatar
I run the summit pump and I didn't trim the fan shroud, It fit just fine. The only thing with mine was they sent the wrong size freeze plug. Also I run the painless harnes with mine.
Old May 3, 2008 | 08:13 AM
96capricemgr's Avatar
Summit is not a parts manufacturer, well they do own Trickflow but that is about it. The Summit pretty much has to be a CSR or Meziere and the changes/differences guys have noticed are likely just production date changes you would find in the actual manufacturer's pump as well.
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
Stay Puft
Apr 20, 2015 06:24 PM
Queens94z28
Dec 20, 2014 09:11 PM
Zone
Jul 29, 2002 07:43 PM
