Suggestions on shorter plug
Old Jan 1, 2007 | 11:13 AM
95Blackhawk's Avatar
Currently running a Champion RS9YC that is 2 steps colder than stock and want to stay somewhere around this heat range.
The question is: is a plug made with a terminal end that is shorter in length than this Champion?
The reason is my shorty headers are burning up the boot specifically on cylinder 5. I do have heat protecting sleeves on them but the boot is a 1/4" from touching w/o heat protection. Shorter the terminal, farther away from the header.
Any ideas?
Old Jan 1, 2007 | 12:31 PM
reamo04's Avatar
idk how big those champions are, check NGKs and search for the same heat range. can also check autolites
Old Jan 1, 2007 | 12:50 PM
runlt1z28jake's Avatar
Search for lt1 short sparkplug see if that helps. A coulple years ago I went from using ngks to using autolite and have been okay since. The ngks were 1/4" longer on the terminal end. I don't know if the autolites are are shorter than the champion plugs you are using or if you really care to run autolite plugs. I bet it is worth a look. Accell makes a shorty plug also.
Old Jan 1, 2007 | 01:40 PM
jjminch's Avatar
Long tubes...
Apr 16, 2015 09:57 AM
REDNECKISBOSS
Mar 22, 2015 08:31 AM
eazyZ
Mar 1, 2015 07:12 AM
mritter1965
Feb 9, 2015 07:01 PM
cmdeshon
Dec 27, 2014 10:06 AM
