Suggestions for missing/popping at high RPM's?
Old Nov 8, 2007 | 06:52 PM
hleining's Avatar
Just bought a 93 Z28 this week that has a 97 LT1 motor in it with 60,000 miles on it.
Before I bought it, the car sat for about 8 months without being driven, just started up occasionally.
At anything over 4000 rpm it's missing and popping (when I hammer it), and running really rich.
I ran through all the old gas that was in it and put in a fresh tank and it seemed to get a little better (I thought the bad gas was the problem). I noticed the O2 sensor on the passenger side was broken (the wire was not connected/broken). I changed that sensor today and connected it, thinking that could also be contributing to the problem. Now, it's worse than it was before. Any time I put it to the floor it pops/misses really badly at about 4000 rpm, to where it won't shift until I let off. It's fine at lower rpms. It's not throwing any computer codes at all.
Any ideas/suggestions?
Old Nov 8, 2007 | 07:19 PM
jhthornley's Avatar
tons of posts about this... do a search...
for me it was a wasted coil wire.
Old Nov 8, 2007 | 07:23 PM
The Engineer's Avatar
It could be the Opti rotor getting loos, fouled plugs, bad plug wires or several other things.
WD
Old Nov 8, 2007 | 07:37 PM
Z28Freak86's Avatar
I had this problem too. its almost like the engine hits its rev limit. my problem turned out to be the the coil wire that was frayed and broken. unfortunately i had to buy a whole new set of spark plugs to get the wire i needed. so check that, but it definately sounds electrical
cmsmith
Apr 1, 2015 09:29 PM
lt1matt
Mar 21, 2015 07:35 PM
carl.froehlich
Mar 13, 2015 12:38 AM
1996LT1Z28
Mar 8, 2015 08:16 PM
97SSdude
Dec 31, 2014 07:43 PM
