Subframe Connectors?
Old Jul 22, 2004 | 04:50 PM
slayer6x6's Avatar
What is the difference between the 2 different style subframe connectors. It seems that the cheaper kind look like 2 bars with some flanges, and the other type almost has a latter type setup. Is there much of a difference between these 2 styles except for price. Somebody please enlighten me. Heres 2 examples.
Latter type: http://cgi.ebay.com/ebaymotors/ws/eB...category=42609
Bar type: http://cgi.ebay.com/ebaymotors/ws/eB...category=42609
Old Jul 22, 2004 | 04:59 PM
z28marine's Avatar
Re: Subframe Connectors?
the diamond looking ones will provide alot more support and a tighter feel...they are better
Old Jul 22, 2004 | 05:36 PM
CamaroBoy96Z28's Avatar
I wouldnt exactly say that the diamond style is better although they are stronger. They can become obstructions if you want to go with a more custom exhaust setup or some other components on the underside of the car. More or less DD SFCs are overkill unless you need the ultimate in strength SFC. For the most part, tubular or boxed SFCs will give you all the strength you need in a straight line and handling depending on what your goals are and how rigid the chassis needs to be to meet those goals.
Old Jul 22, 2004 | 05:46 PM
slayer6x6's Avatar
Well in that case, Ill probably go with the cheaper ones then. The car is my daily driver so I dont plan on road racing it anytime soon. Do you prefer the bolt in, or weld in style?
Old Jul 22, 2004 | 05:58 PM
Lyle A's Avatar
Before you jump into it, check out BMR and other sites like that. The second link you provided looked kind of cheap and not easy or effective. The SLP's are overpriced.
Old Jul 22, 2004 | 06:00 PM
Bow94z's Avatar
weld-ins are better. although i have the SLP Bolt in SFC's i picked them up for 125$ so i couldnt turn that down. im running borla and they dont get in the way.
But yea WELD-IN is the way to go. bolts break to easy!!mad:
Old Jul 22, 2004 | 06:03 PM
Lyle A's Avatar
You could always weld the SLP's after they are bolted in place. There are some that are bolt/weld combinations.
Old Jul 22, 2004 | 06:04 PM
slayer6x6's Avatar
Cool, thanks guys
Old Jul 22, 2004 | 06:08 PM
ABA383's Avatar
Check out Hotchkis, too. They tuck up nice...a bit pricey, but mine have been welded in since 1995. Their powder coating is first rate, too. Plenty strong and effective with no clearance issues with exhaust...
--Alan
Old Jul 22, 2004 | 06:14 PM
mrz28 73/97's Avatar
I wouldn't buy sfc's based on price alone and the "straight" ones in the link don't look strong at all and I wouldn't buy them. I have personally had both types Global West straight on my last SS and SLP weld on's on my current SS and both are great but the Diamond style do stiffen the car considerally more and I like a stiff chassis so the SLP weld ins would be my choice.
Old Jul 22, 2004 | 06:26 PM
1984camaroz28's Avatar
the Bar type are not worth the money. save ur money and buy the other ones
Old Jul 22, 2004 | 10:39 PM
revtime's Avatar
Double Diamonds.
I had a set welded in about 6 years ago and they still look good. Best mod you can do for a car that will be driven alot.
Jeff1904
Jun 5, 2016 05:00 PM
football4life
Oct 4, 2015 07:48 AM
Double aught
Oct 2, 2015 11:29 PM
autoxr166
Sep 25, 2015 04:21 PM
frankrizz
Sep 23, 2015 04:21 PM
