stupid question
Old Mar 9, 2005 | 09:26 AM
94TA_LT1's Avatar
stupid question
can u bolt a 383 crank made for 5.7" rods into a stock 350 short block and have it work? or would the compression ratio pn the pistons be all wrong?
Old Mar 9, 2005 | 09:35 AM
1racerdude's Avatar
Re: stupid question
You have to have pistons to go with the stroke.
Old Mar 9, 2005 | 09:44 AM
94TA_LT1's Avatar
Re: stupid question
and then u might as well have new rods for the hp too right?
Old Mar 9, 2005 | 09:49 AM
BRENTT94Z's Avatar
Re: stupid question
Yes, Its a 3.75 stroke crank, but you need to clearance the block. You EDIT: cant use the stock pistons. You can use stock rods but it wont be a true 383. It turns out to like a 377.
1racerdude's Avatar
Re: stupid question
It's better to buy a "Kit" than try to piece it together if you don't have the experience.
Old Mar 9, 2005 | 10:02 AM
94TA_LT1's Avatar
Re: stupid question
well heres what i have now..a forged bottom end 350 and i wanted to just swap out the crank for 250 and have a 383 or 377 or whatever..so would the compression ratio still be fine then w/o changing pistons?
Old Mar 9, 2005 | 10:03 AM
94TA_LT1's Avatar
Re: stupid question
or am i better off sticking with the 350 forged bottom with the 847 cam insted oh having to go get a new cam and all since i doubt it will add that much hp with the heads i'm running
Old Mar 9, 2005 | 10:09 AM
Re: stupid question
No. You can't use a 3.75" crank with pistons made for a 3.48" crank. The stock pistons will be pushed 0.135" further up the bores by the longer crank throw, putting them into the head. You need a piston to "match" the longer crank throw.... basically the wrist pin needs to be dropped 0.135".
Old Mar 9, 2005 | 10:14 AM
94TA_LT1's Avatar
Re: stupid question
ok, i was thinkong something like that but you'll had me confused for a sec..i'm sticking 350 forged bottom and just spraying it for now..thanks
Old Mar 9, 2005 | 10:24 AM
BRENTT94Z's Avatar
Re: stupid question
He's right,
I was on a typing spree not reading what I wrote. You can use the stock 5.7 rods but you need new pistons, I dont know why anyone would want to go that route though.
Sorry for the misconseption.
Magenta_Hearts
Mar 5, 2015 07:01 AM
cmdeshon
Dec 27, 2014 10:06 AM
brentbrowning01
Dec 16, 2014 06:35 AM
ChrisFrez
Dec 15, 2014 03:09 PM
Brent94Z
Mar 21, 2002 04:44 PM
