Stupid drivers side header!
Old Jun 18, 2004 | 03:13 PM
94NDTA's Avatar
Allright, I have my car high enough in the air, I have my alt, starter, steering, old manifolds, oil filter removed. The drivers side is suppose to be the easiet right? It isn't going in. I have only read about people jacking the motor mount up on the passager side (which I havn't even started yet). Can I jack up that side of the engine too to try and get it in?
EDIT: I have jet hot long tubes.
Old Jun 18, 2004 | 03:17 PM
Will84's Avatar
You can jack up the motor, but be careful to not tear the other engine mount or the tranny mount.
Old Jun 18, 2004 | 03:22 PM
Flyin_Z28's Avatar
Are you installing the Jet hots by yourself or with a friend. Someone to help you makes it a lot easier. I installed my drivers side header with no problems. Jack the car as far in the air as possible. The header is easiest to install from the bottom. I believe you tilt the collector towards the passenger side of the car. Your going to have to play around with the angles. Plan on at least 8-10 hrs for the install.
What are you doing about a y-pipe?
Old Jun 18, 2004 | 03:32 PM
IllusionalTA's Avatar
Have you taken the slip fit out? try pulling the steering shaft off as well.. you'll realize that the driver's side is cake compared to what your going to go through for the passenger side..
Old Jun 18, 2004 | 03:34 PM
94NDTA's Avatar
I tried from the bottom but gave up quick because it looked imposible. I'll give it another go. Any tips on jacking up the motor.
The steering linkage is out as well as is the slip fit.
Old Jun 18, 2004 | 03:35 PM
)2overt SS's Avatar
My driver side went in very nicely..
Just play around with it for a while. You'll get it eventually. It's tricky with the K-Member sticking out. If I remember correctly.. I tilted the collector so the opening was at about a 45 degree angle to the ground, and then just wiggle it around.
My passenger side was harder.. but only because I had to jack up the motor. And even that wasn't very hard. It's just one bolt and one nut... A lot of people stress over that for some reason
Old Jun 18, 2004 | 03:36 PM
94NDTA:
You might want to delete this thread before the "LT1 Tech" modrator sees this.... a definite violation of board rules.
Old Jun 18, 2004 | 03:43 PM
94NDTA's Avatar
Is it the title? I didn't think it would brake any rules.
oh yeah.....
Old Jun 18, 2004 | 03:45 PM
camaroragtopz28's Avatar
hey
Originally posted by Injuneer
94NDTA:
hey what does that mean what kind of rules are you talking about. if you are just playing im just a dummy but if not enlighten me.
Old Jun 18, 2004 | 03:49 PM
Re: hey
Do not over-ride the language filter.
Old Jun 18, 2004 | 03:51 PM
94NDTA's Avatar
Is there anyway you could edit it so I don't need to start a whole nother post?
Old Jun 18, 2004 | 05:12 PM
Red96Lt1's Avatar
My driver's side was the hardest. I had to grind down the K member. Hope that helps.
Old Jun 18, 2004 | 05:49 PM
speed76demon's Avatar
I hear ya passenger side went right in then the drivers side was a bitty took forever. Had to jack it up
Old Jun 18, 2004 | 06:04 PM
95 Z/28 LT1's Avatar
Super Moderator
Actually, it is against the rules. Please don't override the language filter.
Old Jun 18, 2004 | 10:43 PM
oh yeah.....
Do you realize that most of the moderators are the same guys that come here mainly to help people.... I can tell you its really frustrating to sign on hoping to read some interesting posts and spend time helping people, but you can't because you have to start editing posts and moving things to the correct forum. It means that a few people who could have been helped got ignored, because the moderator was busy straightening things out....
Just my personal view.
