Stupid Cooling Fans!!! @#$%&*!!!!!
Old Feb 2, 2003 | 12:29 PM
  #16
It really needs to be monitored with a scanner to see what temp the pcm sees. That input will determine what the pcm will do. If the pcm sees the temp high enough that it should turn on the fans and does not, then there is a problem with the pcm. Are you sure that the temp is getting high enough for the fans to turn on? Stock ON fan temp is 226º. Even the dash gauge could be lying to you, since it derives it's temp from another sensor.
You could always try resetting your pcm for the lack of anything else to do.
Old Feb 2, 2003 | 01:16 PM
  #17
TechCam97's Avatar
Hey shoebox, do you think that a messed up thermastat could cause this problem?
Old Feb 2, 2003 | 02:30 PM
  #18
A malfunctioning thermostat might make the car run hot, but won't have anything to do with the fans not coming on.
Old Feb 2, 2003 | 03:15 PM
  #19
TechCam97's Avatar
Dang...that's what I thought....well, I'm in the middle of just wiring my fans up manually. I just got sick of spending all this money on my car to fix something that I couldn't put my finger on. Thanks for all your help though!!!
warmeck
Jun 5, 2015 05:19 PM
timmy39120
May 8, 2015 11:41 AM
LingenfelterZ28
Apr 25, 2015 10:24 PM
LingenfelterZ28
Apr 24, 2015 02:00 PM
Biggiebound
Apr 23, 2015 08:50 AM
