stumbling at low rpm and wot sometimes
Old Dec 11, 2005 | 07:27 PM
95M6Z's Avatar
i just got an msd opti & new plugs and wires in the past month but now my car is stumbling at idle, sorta like when the opti was goin and at wot it stumbles then goes then stumbles.....im clueless. at idle it idles then like skips a beat and fluctuates about 100 rpm up and down for a second. anyone have input i would GREATLY appreciate it, thanks
Old Dec 11, 2005 | 07:30 PM
wrd1972's Avatar
Re: stumbling at low rpm and wot sometimes
I have seen the coil wire do this. Make sure its full connected on both ends as well as all the plug wires.
Old Dec 11, 2005 | 08:09 PM
LenT1's Avatar
*off topic*
How much did that opti run you? Was that the new msd system complete?
Old Dec 12, 2005 | 11:51 PM
95M6Z's Avatar
thanks for the wire advice.....and the opti ran me $159 canadian, plus the base which was around the same if i remember correctly....its cheaper than the gm cap and rotor, looks much better too but its not too easy to see it. but again thanks for the advice
Navecm
Jun 1, 2015 05:57 PM
AlaskaZ28
Jan 1, 2015 12:30 PM
AlaskaZ28
Dec 16, 2014 07:24 PM
AlaskaZ28
Dec 10, 2014 02:39 PM
AlaskaZ28
Dec 10, 2014 02:37 PM
