Stumble and revving at idle
Old Feb 11, 2005 | 02:50 PM
Detroit808's Avatar
My 94 z28 started having stumblig problems yesterday. Basically, the car was in traffic a long time, then the engine starts to stumble/rough idle, and the check gages light goes on. The oil pressure reads low, just sitting over the redline, and it's running at 500 rpm. I should mention, it's been reading low for the 2 years I've had the car, so those marks seem normal. Suddenly, the engine revs to about 1000 rpm, then drops back down to 500. A day later, the car runs fine, but I need to figure this out. Just to throw these out there...I've searched posts suggesting it might be oil pressure sensor related, time for a tuneup (It's got 70k miles, stock plugs/wires), or something more serious. Any ideas?
Old Feb 11, 2005 | 03:30 PM
Eck's Avatar
Eck
Re: Stumble and revving at idle
The CHECK GAUGES light came on? Did you look at the temperature gauge?
Old Feb 11, 2005 | 03:42 PM
Detroit808's Avatar
no problem with the temp gauge...below 200
Old Feb 11, 2005 | 04:03 PM
Tibbys96Z's Avatar
I wouldn't be comfortable with that low of oil pressure. I'd change the sending unit to be sure, if it was still low, I'd rebuild. Crank and cam bearings etc. I'd also do ALOT of upgrading to aftermarket parts.
Old Feb 11, 2005 | 04:08 PM
Detroit808's Avatar
Would a bad sending unit cause stumbling like that? And what about the engine revving to 1000 rpm? Thanks for the responses.
Old Feb 11, 2005 | 07:27 PM
Hawk's Avatar
IAC man, it controls the idle speed. I'd check that out.
Brian
Old Feb 12, 2005 | 02:58 PM
Detroit808's Avatar
Okay, I think it's narrowed down to TPS or IAC. The low oil pressure could be a red herring, but in any case, I'd like to address that problem after this phantom revving is taken care of. Which one, TPS or IAC, matches the symptoms more?
Old Feb 12, 2005 | 06:09 PM
CrockRocket94's Avatar
Last year mine had those same issues.
It actually creeped me out when it would jump rpm's at idle, from 600 too ~1000 and back down.
I changed my optispark and that cured it.
But along with the opti, i changed wires and plugs, and then put a new transmission in the car.
So it could be a number of things, because for me it wasnt the IAC.
Formula Steve
Sep 19, 2023 08:31 AM
Nayr
Mar 3, 2023 08:34 PM
tdigger9899
Sep 7, 2015 10:56 AM
GusarskiSS
Exhaust System
Sep 2, 2015 03:51 PM
C4m4roJoe
Jul 19, 2015 10:59 PM
