studder! Need Help!
Old Mar 11, 2004 | 09:54 AM
skaterz28's Avatar
Angry studder! Need Help!
Hey Guys I know this topic has beed posted before but i need some advice! I have a 93 z28 6-speed, after it gets warmed up it does that that studering ****! mostly from 1500 -2200 rpm, but only under a load (when i let out the clutch) or the clutch is already engaged. also if i flutter the gas it seems to help with the studder ,but if i push in the cluth it runs fine! i've replaced the optispark, the O2 sensors, EGR, Plugs, Wires,and the Fuel filter. i'm stumped! i do have a valve tap! so if anyones got any ideas please send them my way i'm so Frustrated with this problem! i live in st.pete FLorida if anyone knows a camaro specialist let me know!
Old Mar 11, 2004 | 10:33 AM
skaterz28's Avatar
Any info Guys?
Old Mar 14, 2004 | 08:55 PM
skaterz28's Avatar
T T T
Old Mar 14, 2004 | 09:09 PM
akobak's Avatar
triple check your plug wires. Make sure their all snaped in properly. I had the same prob. one of the plug wires wasnt snaped in all the way on the opti side. The car will run decent at first then will buck a little at low rpms when warm. and loss of power will be an issue also. Did you knotice loss of all around power
DetroitZ28
Feb 13, 2015 07:33 AM
Kevin_97
Apr 7, 2005 12:49 PM
Chris 96 WS6
Oct 19, 2004 07:21 PM
Chris 96 WS6
Oct 18, 2004 11:02 AM
Finchinater
Sep 23, 2004 12:30 PM
