4L60E hanging/studdering at WOT 2-3 upshift
Old Oct 17, 2004 | 07:44 PM
Chris 96 WS6's Avatar
Car originally came with 3.23 gears, and with my current heads/cam combo I have run as fast as 12.26 @ 110mph.
Since installing 3.73s in the spring, the car has not shifted right from 2-3 at WOT.
What happens is it gets to the 2-3 shift and it will act almost like its hitting the rev limiter...studder, then shift. It is NOT the rev limiter as that is set at 6300rpm and the shift should be occuring around 6050rpm. I tried upping the limiter all the way to 6500 and dropping the 2-3 shift by 6mph that night at the track and it STILL studdered.
I had scaled the shift tables using LT1 edit, and was concerned I had some errors in the tables, so I went as far as to manually enter the values in the tables 1 at a time. At the track in March I managed only 12.50s all night at 109mph. SLOWER than with the taller gear last fall.
After that, it seemed to shift fine on the street. Yesterday I went to the track and it shifted jsut fine the first time, but my ET was a dissappointing 12.54 @ 107. There was a pretty strong headwind costing most guys 2mph in trap speed, so lets call it 12.53 @ 109.
I am flat out not getting the HP to the wheels I should be. NOthing has changed in the motor, the only change is the gears. THe trans seems to shift OK when its cold or cool, and when it gets hot is when it starts to studder.
I have a Vig 2800 and B&M tranny cooler. I've had those two items in for nearly 3 yrs and am just now having the problems since the gear install.
What is the issue here? Something mechanically wrong with the trans? Could it be slipping in 3rd gear enough to cost me ET/mph and not really be noticeable to me?
Old Oct 18, 2004 | 11:02 AM
Re: 4L60E hanging/studdering at WOT 2-3 upshift
Beuller? Beuller?
Anybody have any input or experience they can share?
Parts Wanted
May 1, 2016 10:25 AM
blac94Z
Nov 4, 2015 01:59 PM
PopoFormula
Oct 12, 2015 04:19 PM
Mikes 1994 z28
Oct 10, 2015 07:55 AM
SEOJustin
Sep 24, 2015 04:39 PM
