stud girdle
Old Aug 5, 2003 | 07:45 PM
hotrod 95's Avatar
stud girdle
Has anyone used a stud girdle on LT-1 heads. If so how and what kind or would shaft rockers be better?
Old Aug 5, 2003 | 11:25 PM
4drLT4's Avatar
I'm running one on my AFR heads...close enough?
Old Aug 5, 2003 | 11:45 PM
SStrokerAce's Avatar
You might not even need one. Going with 7/16 studs and a very stiff rocker arm like a Hi Tech stainless Comp setup is going to net you enough for a street car. All depends upon your spring pressures and cam that you are running.
A Comp 4009 or 4004 are a good setup if you are looking for one. Shaft mounts and the associated price are really not worth it.
If you need any help on this shoot me a e-mail. I can hook you up with one if needed.
Bret
Old Aug 6, 2003 | 12:11 AM
kmook's Avatar
Advanced Tech Moderator
Quite a few people have run them around here on the board. Usually only if you cant afford a set of shaftmount rockers though, as they would be a better choice in most cases.
But this question would be best suited for LT1 Tech, moving.
13qtr
Oct 28, 2016 08:11 PM
karpetcm
Sep 15, 2015 11:07 AM
mmf_1013
Sep 12, 2015 08:56 PM
Daluchman1974
Sep 11, 2015 06:12 AM
FryedClutch
Sep 1, 2015 08:24 AM
