Stuck In River
Old Oct 27, 2004 | 07:03 PM
  #16
BoobSter-lt1-z's Avatar
Re: Stuck In River
I took the car to the shop in a tow trucked....
The body of water didnt look deep, unfortunately, i couldnt see how deep it was until i hit it with the car...i told my friends about it and they said that the intersection i went through has dips and when it rains as hard as yesterday, the dips can accumulate about a foot to a foot and a half of water.
I removed the mass airflow sensor and it was full of water and that little plastic stick that hooks to the elbow and runs down to the bottom near the floor was full of water...
So what am I looking at? A new engine? Rebuild?
Old Oct 27, 2004 | 08:07 PM
  #17
92rslt1's Avatar
Re: Stuck In River
well i will lay it out like this.. worse case scenario you bent your rods but maybee its just hydo locked still. change your oil take your plugs out.. NOW .. get that water out asap. a cylinder can acumulate surface rust before your very eyes within minutes. you might need a new maf and definatly make sure that water is all out of your engine.if it was mine i would take the intake off and make sure everthing was dry in the heads before i attempted starting it. however i guess you could pull all the plugs take the tb off clean all the water out of the manifold blow compressed air into the cylinders and a shot of wd40 try and get all the water out let it sit and then when all dry see if it still runs. you never know may not have done anything. theres realy only two options for you at this point.
just tear it apart and rebuild it.
or get the water out try to run it if not tear then it apart to rebuild.
if it does run dont be suprised if it burns oil and smokes.the water seeps between your rings and it doesnt make for a very freindly lubricant.
Old Oct 27, 2004 | 09:22 PM
  #18
Re: Stuck In River
Just Picked Up The Car From The Shop. They Pulled The Plugs And Turned The Engine Over Manually And They Saw Shots Of Water Out Of All 8 Plugs. The Car Starts And Runs Now.
Thanks A Lot To Everyone For All Their Input! It Is Greatly Appreciated!
A Mistake And Lesson Learned!!
Old Oct 27, 2004 | 09:56 PM
  #19
Black94mula's Avatar
Re: Stuck In River
My buddy bent a rod from the exact same scenario. I told him everything everyone told you here, you got lucky man. Also, change that oil again soon..
Old Oct 27, 2004 | 10:08 PM
  #20
Z95m6's Avatar
Re: Stuck In River
I'm glad you got it fixed. Thats just another reason i'm glad i went to the Ram Air set up.
Old Oct 27, 2004 | 10:19 PM
  #21
Re: Stuck In River
I am gonna change the oil saturday and put a new air filter.... it hurts my wallet because i had just changed the oil about 1 month ago with royal purple oil
Old Oct 28, 2004 | 12:21 PM
  #22
simple's Avatar
Re: Stuck In River
i would change the oil a couple times at earlier intervals with cheaper oil too be on the safe side (maybe twice in a 1000 mile period) then go back to normal routine
good luck with it and glad too hear nothing major happened
Old Oct 28, 2004 | 04:55 PM
  #23
Alvin@pcmforless.com's Avatar
Re: Stuck In River
Ha ! I was right ::
Change the oil immediately, even if you have to put a cheaper oil in it. Dont' drive the car until you do.
Old Oct 28, 2004 | 05:28 PM
  #24
95 Z/28 LT1's Avatar
Super Moderator
Re: Stuck In River
If it was me I would be having the insurance company buy me a new engine.
Old Oct 28, 2004 | 07:56 PM
  #25
Dave88LX's Avatar
Re: Stuck In River
Man isn't that the first thing everyone here told you to do with it?
Old Oct 28, 2004 | 10:03 PM
  #26
Re: Stuck In River
Some of us tried. <shrug>
Old Oct 28, 2004 | 10:38 PM
  #27
thork's Avatar
Re: Stuck In River
Whew! Just read this whole thread, and I'm very glad to hear everything is OK. You definitely lucked out there pal, but congrats on its returning back to life!
Old Oct 29, 2004 | 01:02 AM
  #28
92rslt1's Avatar
Re: Stuck In River
yep he definatly got lucky but i bet he learned from it. others have had harsher lessons.
Old Oct 29, 2004 | 03:54 PM
  #29
Thumbs up Re: Stuck In River
WEll those regular oil changes will come every 3 weeks just to make sure i dont leave anything behind thats not supposed to be there.
I know how much everyone stressed at the beginning of the thread that i should pull a plug but it just looks to hard and my car was on the street and there was too much water flowing to risk lifting up the car with a jack. I was afraid of snaping a plug in the process so i left that till the end which was
not a very smart choice...but she is alive...the only difference now is the way it starts sounds like it makes more metal contact (might be the starter) and the air pump sounds a bit louder but it might just be the water (i think its the air pump)
ONCE AGAIN.... THANKS A LOT AND I GREATLY APPRECIATE EVERYONES HELP!!!
68camaroboltz
Oct 5, 2015 11:56 PM
buggy323
Jul 1, 2015 04:37 PM
sherwinZ28
Jun 6, 2015 08:48 PM
tds1213
Nov 27, 2014 12:55 PM
panterachik00
Middle Atlantic
Aug 10, 2002 10:27 AM
