Stuck on plug change!
Old Jun 13, 2004 | 01:28 PM
  #16
gb95zconv's Avatar
Originally posted by Daddy2K3
I just laid on top of the motor. I didn't take the starter out.
Ratcheting gear wrench is your friend when changing plugs.
Old Jul 1, 2004 | 09:05 PM
  #17
944v8inDFW's Avatar
This may sound silly
Because of my headers most of the plugs are very difficult to get off from the top. I now do my plug changes from under the car! Top plug change = 1 hour min. Bottom plug change less than 15 minutes. Most of that is getting the car on ramps and blocking the wheels. Just a thought. I also have a mini starter that hangs low and that i am sure helps on the pass side. One tip from under the car is disconnect the neg. battery cable. I was pretty close to the starter lugs when changing mine.
Old Jul 1, 2004 | 09:15 PM
  #18
25thBird's Avatar
plugs can be accessed from the bottom with headers on?
Old Jul 1, 2004 | 09:19 PM
  #19
944v8inDFW's Avatar
On mine yes, look at my tag line however!
Old Jul 1, 2004 | 11:47 PM
  #20
DrewHMS97SS's Avatar
dont be lazy, the alt is only 3 bolts
Old Jul 2, 2004 | 12:08 AM
  #21
25thBird's Avatar
The connector should come off easy, just tug the boot a little harder. The #7 and 8 are easy from the bottom.
Dark Zeiro
Mar 11, 2015 07:15 AM
captcorvette
Mar 7, 2015 12:37 PM
jasonduaine
Mar 7, 2015 09:44 AM
grgguy
17
Feb 23, 2015 07:57 PM
30thZ4C
Dec 26, 2014 05:09 PM
