stuck injector
Old Oct 27, 2003 | 03:32 PM
deadhead1882's Avatar
stuck injector
i think one of my injectors is stuck, theres a clicking sound coming from the engine causing a miss, what ways can i check to see if ive got a bad injector
Old Oct 27, 2003 | 03:58 PM
GREGG 97Z's Avatar
You can check them with an automotive stethescope. Hold the point of it up to the injector with the engine running, it should make a rapid ticking sound if it's working right. You can get one at most auto parts stores, they are only around $10 for a cheap one, they are a very good tool to have. If you can actually hear the clicking sound normally I really doubt it's an injector, more likely a rocker out of adjustment or something else.
Old Oct 27, 2003 | 05:27 PM
thanks, ill pick one of those up later tonight and check it out, how difficult is it to readjust a rocker
thanks
Old Oct 27, 2003 | 06:40 PM
slopokrodrigez's Avatar
More than likely the clicking you hear is a plug wire firing to ground through the side of wire. This is giving you the miss.
Old Oct 27, 2003 | 06:59 PM
thanks ill try that one also
13qtr
Oct 28, 2016 08:11 PM
93 RedBird
Nov 15, 2015 08:24 AM
plattted
Parts Wanted
Sep 13, 2015 07:17 AM
RubyRedIrocZ
3rd Gen / L98 Engine Tech
Sep 10, 2015 01:48 PM
plattted
West South Central
Sep 7, 2015 02:45 PM
