Price help on 383 build...
Old Oct 27, 2003 | 06:07 AM
AxeGrinder30thZ's Avatar
I'm lookin' to rebuild my 97 LT1 into a 383 next year. I need to start saving now. I have been lookin' around for stroker kits, and I think I want to go with this one. 383 kit
I'll probably get the custom balancing, and up grade to Eagle H-Beam rods. Don't know if I can afford the Eagle 4340 crank. So that should put me at $1525 for the kit. Around how much will I be looking at to get my engine rebuilt with this 383 kit? Thanks guys.
Old Oct 27, 2003 | 06:41 AM
kmook's Avatar
Advanced Tech Moderator
This question should be asked in LT1 Tech.
Moving, Thanks.
Old Oct 27, 2003 | 06:47 AM
GhostZ's Avatar
Check out the GP section and see when cmotorsports is going to do another stroker GP.
Or give them a shout. www.cmotorsports.com
Old Oct 27, 2003 | 06:59 AM
Kyle@CSS's Avatar
I just built about the same kit. I did go with the 4340 and h beam rods. The machine work was 500.00. the balancing was like 125. beacause i went with the 4340. I built the engine myself. Saved money there.
Old Oct 27, 2003 | 07:57 AM
Hey Kyle, how much would you charge to rebuild mine into a 383 if I supplied this kit to you?
Old Oct 27, 2003 | 11:28 AM
Kyle@CSS's Avatar
I will send you a PM on www.scfyb.com
Old Oct 27, 2003 | 11:41 AM
S.J.S.'s Avatar
Hey Axe......just save as much as you can dude. There is way more to it then just the motor. I got my 383 sitting right here. We were putting it together on sat. and realized that with the Eagle Rods.....the oil pan doesn't clear. Also the windage tray needed to go. I just got off the phone with Nu-Tek and had to order a Canton Pan. $400.00 shipped w/oil pump and pick-up.
Not to mention bigger Tb...bigger injectors...comp reprogramming....gotta do head work (a must). I'm about 3 g's over budget. But what the hell you only live once and might as well do it right when your in there. I don't believe in skimping around on such a project.
Old Oct 27, 2003 | 11:49 AM
I know man. I don't plan on dropping a 383 into my car w/o upgrading anything else. I already got a 52mm TB. I can't do this 383 build for about a year, so it gives me plenty of time to get my cam, rr's, etc. I am gonna do head work, but I just don't know what I am gonna do yet. I really don't want to get my stock heads ported/polished, but if I can't gather enough money, then I guess i'm stuck doing that. I want a set of AFR's.
jonaddis84's Avatar
Why did you have to buy a canton pan, people do 383s, even 396s all the time with stock pans and windage trays, just takes a little bending.?
Old Oct 27, 2003 | 11:55 AM
S.J.S.'s Avatar
Well...did a lot of research and only 1 guy bended his windage tray. Still can't figure how he did that. Most people with the stock pan don't even run the windage tray and either grinded or bent the pans with a hammer. Not saying that aint good...I'm sure its fine but just for me I decided not to. Without the windage tray you'll lose some HP in the higher RPM's andyour oil pump could cavitate if your running a high volume. Rather just do it right. I figure I'm spending all this money ..."just do it!"
Old Oct 27, 2003 | 11:56 AM
Dave88LX's Avatar
What do you want the car to do HP wise etc? If nothing outrageous you can do a Scat9000 type crank and some 4340 forged I-beams, and spend the money elsewhere...
Old Oct 27, 2003 | 12:11 PM
jonaddis84's Avatar
Gotchya, I didnt realise people with stock pans were not running windage trays, is it possible to run an aftermarket windage tray in a stock pan, like a milodon?
Old Oct 27, 2003 | 12:15 PM
I'm not exactly sure what I want HP wise. I don't want to build a freakin' monster or anything. I still want to be able to drive it on the street. I will most likely add nitrous. I don't want like a 600 hp car or anything.
Old Oct 27, 2003 | 12:24 PM
S.J.S.'s Avatar
Yeah....its called a Milodon Diamond Stripper Tray. Like 80 bucks or something from Summit. But even that needed some modification. I guess I just rushed it...but being in Hawaii, shipping sucks. Too many times did I order crap and not be able to use it and to send it back costs too much. Thats the reason I went with the Canton.
Here's a pic of fastblacks one.
http://fastblackz28.cz28.com/images/engine_2.jpg
Old Oct 27, 2003 | 12:25 PM
jonaddis84's Avatar
Thats the tray I was thinking of, and you say it doesnt work still with a stroker crank? Also that link wont let me go to it, it says forbidden.
