struts suck
Old Feb 23, 2004 | 10:49 PM
  #16
LT1 Bunny's Avatar
I know it souns kinda redneck but I'm gonna do it. I'll post to tell details.
Old Feb 23, 2004 | 10:55 PM
  #17
ledfootz28's Avatar
any p/n on those seats?
Old Feb 29, 2004 | 09:04 PM
  #18
LT1 Bunny's Avatar
that seriously sucked a$$. i tried to cut through the shock shaft...there was no chance in hell anything could cut through that metal. the only thing i could see cutting through it was an acetylene torch, but thats not too smart . i had to drill out the bolt, and then of course pop out that dog biscuit...and the pain was finally over! ive got to do the other side now and i really dont want to take off the master cyclinder, but you gotta do what you gotta do!
Old Feb 29, 2004 | 09:09 PM
  #19
Do your master cylinder like this and you don't have to open any brake lines. It's not a big deal at all. Just remove the plastic line separators and move the mc slowly.
Old Feb 29, 2004 | 09:20 PM
  #20
Grover's Avatar
Shoebox, do you have a part # for the dog bone things and the nuts that go on the top of the shock rod?
Old Feb 29, 2004 | 09:39 PM
  #21
Nut GM PART # 11516077
1993-2002 upper shock insulator
(dog biscuit under top shock nut) 17999212 (was on my part numbers page)
Old Feb 29, 2004 | 09:56 PM
  #22
Grover's Avatar
I looked on your part number page, but I didn't know what the real name for it was.
Old Jan 22, 2005 | 05:46 PM
  #23
Mizz96Z28's Avatar
Re: struts suck
I just did this job today and I ended up having to grind down the nut then I just kept hitting it with a hammer till it finally gave but when I was grinding the nut, I hit the rubber peice a few times and it ripped in one place so I will replace it but what exactly does it do? It lookes like it sits below the mounting surface of the upper mount so it doesn't even look like it makes contact with the upper wheel well. Does the top actually deflect enough while driving to make contact with the inner top wheel well so they put the rubber there to soften it almost like the bump stop in the rear or what? I'm kinda curious to it's actual function.
Myles
Old Jan 23, 2005 | 12:44 PM
  #24
LT1 Bunny's Avatar
Re: struts suck
actually...i havent even thought about what that "dog bone" is really for.....mine were covered in dirt/sand/mud/everything else! So, there has to be a gap er somethin!
Jeff1904
Jun 5, 2016 05:00 PM
Kawi
Sep 28, 2015 09:01 AM
drt
Sep 27, 2015 04:39 PM
92_RS_305
Sep 8, 2015 07:47 PM
force10
Jul 30, 2015 04:56 PM
