Stroker clearancing
Old May 6, 2005 | 07:03 PM
69vette's Avatar
Stroker clearancing
Ok, i'm in the process of building a 383 and am planing on heading up tho the machine shop tommorrow to clearance my block. My question is should i cleanance the block fully or grind some off the bolt heads? I'm running the lunati crank and eagle h beams with L19 bolts. Thanks and if you have any pics of your stroker clearancing, post them up.
Old May 6, 2005 | 07:40 PM
captaindbol's Avatar
Re: Stroker clearancing
All your clearance work should go into the block(oil pan rails and cylinder bottoms). Rod grinding is usually reserved for camshaft clearance issues.
James
Old May 6, 2005 | 08:14 PM
SStrokerAce's Avatar
You have to clearance that thing like a 396 along the pan rail with H beams and L19 bolts!
Always clearance the block not the head of the rod bolt.
Bret
Old May 6, 2005 | 09:03 PM
69vette's Avatar
yeah i figured i should only due the block but when i searched, some people were mentioning grinding the head bolt but that seemed like a bad idea so i wanted to check.
Old May 6, 2005 | 09:04 PM
69vette's Avatar
got the cam from you yesterday also bret. thanks for all the help
RUENUF
Mar 13, 2016 03:37 PM
Z Power
Sep 19, 2015 11:19 PM
karpetcm
Sep 15, 2015 11:07 AM
95craz28
11
Sep 12, 2015 07:47 AM
sleeperZ96BT
Sep 10, 2015 08:01 AM
