Stripped transmission mount bolt hole.
Old 10-12-2003, 03:12 AM
Eddie95Z28's Avatar
What is the best way to repair a transmission mount bolt hole that is stripped? I figure I have two decent options. 1-Tap the hole to a bigger size bolt. Or, 2-Heli-coil the bolt holes. I figure tapping should be a bit easier. Any other ideas or reccomendations ?
Eddie95Z28 is offline
Old 10-12-2003, 03:36 AM
QCKZ28's Avatar
are you talking about the actual tranny mount? or the mounting hole in the tranny?
QCKZ28 is offline
Old 10-12-2003, 10:08 AM
96bird's Avatar
i had the same problem with mine what i did was tapped out the holes & studded them seemed to work pretty good havent had any problems yet
96bird is offline
Old 10-12-2003, 12:34 PM
Eddie95Z28's Avatar
QCKZ28: I am talking about the threaded holes in the tranny where the mount goes.
96bird: How would I stud a stripped bolt hole ?
Old 10-12-2003, 11:16 PM
Eddie95Z28's Avatar
One more TTT then I'll let it die gracefully.
Old 10-12-2003, 11:22 PM
madwolf's Avatar
I think tapping/helicoil are your only options. I'd tap it myself.
madwolf is offline
Old 10-13-2003, 12:28 AM
QCKZ28's Avatar
i agree with madwolf. tap it.
QCKZ28 is offline
Old 10-13-2003, 10:04 AM
96bird's Avatar
you have to tap out holes in trans & install a stud with locktight
96bird is offline
Old 10-13-2003, 11:35 AM
96 WS6's Avatar
I pulled the tranny, it only takes an hour or two. Took it to the the machine shop and had both holes heli-coiled and studded.
96 WS6 is offline
HectorM52
07-30-2017 11:46 AM
maybe2fast
03-16-2015 09:45 AM
Jazsun
12-29-2014 12:14 PM
Quick Reply: Stripped transmission mount bolt hole.
