Stripped #4 sparkplug
Old Aug 18, 2005 | 07:31 AM
JasonK94Z's Avatar
Angry Stripped #4 sparkplug
Well, thought I had the spark plug started by hand, threw the air ratchet to it with a couple of small taps to see if it really was in right. It wasn't. I think it cross threaded on the first thread. There was a very small sliver of aluminum on the spark plug. I'm thinking maybe just the first thread got crossed. I can't get a plug to start anymore.
try using a tap to chase the threads? What are my options for "on car repair"?
Old Aug 18, 2005 | 07:44 AM
CANTONRACER's Avatar
Re: Stripped #4 sparkplug
You used an airgun on a sparkplug...am I reading that right?
I would probably start witih pulling the headers to give yourself more room and maybe then a tap.
Old Aug 18, 2005 | 07:49 AM
Chris 96 WS6's Avatar
Oh man....NEVER put an air rachet on a spark plug dude....I'd never put an air rachet on anything that threads into aluminum.
You'll have to helicoil it, which means taking off the exhaust manifold at the minimum and pulling the head at most.
Always start plugs by hand and if they don't seem to be going in right then they probably aren't going in right
Lesson learned, I hope?
Old Aug 18, 2005 | 10:42 AM
xsk5's Avatar
if you used an air ratchet then it's probably more than one thread that got screwed up. as was stated a helicoil is the best way repair. a tap probably wont do any good because it will remove metal and the plug might not torque down properly after.
Old Aug 18, 2005 | 10:45 AM
Z95m6's Avatar
I'd try the tap. Whats the worst that can happen. Air ratchets aren't that strong, its not like an impact.
Old Aug 18, 2005 | 11:32 AM
1racerdude's Avatar
The 3/8 I have will pull 60ftlb's,enough to screw up a lot of threads.
Old Aug 18, 2005 | 11:35 AM
slverbullet's Avatar
if you have to helicoil it to fix the problem, your gonna end up pulling that head off. otherwise your going to end up with all those pieces of aluminum shavings in your cylinder. tough having to hear that, but thats probably what it will come down to.
Old Aug 18, 2005 | 11:43 AM
JasonK94Z's Avatar
I ran the ratchet for a split second because I was suspicious of it not starting right. I looked a bit ago with a mirror, and it looks like it may just be the first thread. I'll pick up a tapered tap at work today and see what it'll do.
Old Aug 18, 2005 | 07:02 PM
well, thats good news. good luck with it.
Old Aug 18, 2005 | 11:00 PM
Use a thread chaser-not a tap.
Old Aug 19, 2005 | 07:11 AM
JasonK94Z's Avatar
Thread chaser cleaned it up well! Thanks guys! Lesson learned - Do not work on car after splitting almost an entire case of beer with your friend, and don't use air tools to change spark plugs What was I thinking? Wait, I don't remember
Quickss96
Jan 29, 2016 05:56 PM
pepon214tx
Sep 20, 2015 04:48 PM
Daluchman1974
Sep 11, 2015 06:12 AM
Grimm71
Jun 24, 2015 02:17 PM
Mr.Luna
May 28, 2015 02:22 AM
