strange ticking / ping?????
Old Mar 11, 2008 | 11:16 AM
mazdaman66's Avatar
OK I have a 383 LT1 that runs great most of the time. The other day I pulled out of the shop and let it warn up, hopped in and went for a drive. When I got back to the shop as it sat idling, I hear a tick/ping I give it some gas and it goes away, let is idle ,it's back. It only tick /pings Once per rotation of the motor and only at no throttle. I pulled the valve cover off on the side I can hear it coming from ,every thing is good no bent push rods, no broke springs, no unseated rocker arms, and all the lifters seem to have good pressure (IE you can not push down on any of them ). I would not think it could have any thing to do with the rotating assembly because it would only get more persistent as you gave it more gas and this goes away as you give more gas.
Any ideas??????
I am trying to get a sound clip of this so you hear it.
Old Mar 11, 2008 | 11:34 AM
mazdaman66's Avatar
OK I tried to get it to post I could not get it to work so here is the link
http://s163.photobucket.com/albums/t...urrent=003.flv
Old Mar 11, 2008 | 02:36 PM
mrmint69's Avatar
Did you run it with the valve cover off? This would tell if something is wrong if the noise got louder with the cover off.
Old Mar 11, 2008 | 03:03 PM
mazdaman66's Avatar
No, because the way my LTCC is set up it mounts to the valve cover and grounds out through the cover also so when I take the cover off I will have to come up with another way to mount the coils. If it comes down to relocating them temporally I may have to figure out a way to do that.
Old Mar 11, 2008 | 03:28 PM
joeSS97's Avatar
I listened to it.I would take the belt off and run it.It sounds like the belt chirping .Turn all the pulleys too.
Old Mar 11, 2008 | 04:03 PM
95z28man's Avatar
+1 for the belt
Old Mar 11, 2008 | 04:18 PM
Exhaust leak?
Old Mar 11, 2008 | 04:19 PM
dangalla's Avatar
another vote for belt off
but i dont think its the belt, i think its a weak tensioner
Old Mar 11, 2008 | 04:35 PM
mazdaman66's Avatar
Nope definitely not the belt. I thought of that first. Pulled it no change. Last time I started it it was louder at first then got a bit quieter after running for a few seconds, then went away after giving it gas, then came back after letting off the gas. So to me it sounds like when the oil pressure is up no noise and when its down, hear comes the noise.
Old Mar 11, 2008 | 04:46 PM
dangalla's Avatar
does the noise change at all with temperature of the motor
Old Mar 11, 2008 | 06:02 PM
mazdaman66's Avatar
WE HAVE A WINNER, INJUNEER hit it on the head. I cant believe I missed a header bolt being gone. Re torqued all the header bolts and problem solved..
Thanks for all the input..
Old Mar 11, 2008 | 06:06 PM
jay_rich's Avatar
ya min is bad right nw bc I just changed the oil pump and just reused the header gaskets BC IM IN THE MIDDLE OF SWAPPING MOTORS WITH SOMEONE LOL. I didnt wanna waste 30 bucks on gaskets if i was trading motors right away.
I only ran it for about 20 minutes then she has been hibernating since lol.
Exhaust leaks deff make alot of sound tho lol.
Jay
Old Mar 11, 2008 | 06:08 PM
dangalla's Avatar
welcome to camaroz28, where that happens every day
Nayr
Mar 3, 2023 08:34 PM
RUENUF
Mar 13, 2016 03:37 PM
Quickss96
Jan 29, 2016 05:56 PM
tdigger9899
Sep 7, 2015 10:56 AM
1slow93z28
Sep 1, 2015 06:22 PM
