Strange Ticking noise
Old Aug 7, 2004 | 09:42 PM
97Transam123's Avatar
I own a 1997 Pontiac Transam With a Lt1 engine with 6 speed Transmission.
When i Start up the car every morning to go to work i hear a strange but anoying ticking noice. It really doenst sound as uniform to engine speed as valvtrain noice. but as i leave it idle and stick my head closer to the motor it does sound like its coming from the rear of the engine. Either neat the exhaust or under the valve cover.
Is it also a possibility that it could be some sort of exhaust material Ticking with another metal part?
Just started at this forum, I love how it's setup makes it very easy to find or get the infromation you need.
Old Aug 7, 2004 | 10:10 PM
n2ceptor's Avatar
Re: Strange Ticking noise
Leaking exhaust gasket???
EDIT: Oh, by the way , welcome to the Forum.....
Old Aug 7, 2004 | 10:13 PM
yeah a wee bit new to the forum i didnt know about theserach utility or i wouldnt have posted. this because right after i poseted it i did the search to find the post i just posted and i found the other ones heh
ill look more into that thanks for the info.
Old Aug 8, 2004 | 04:06 AM
aintno6's Avatar
check all your exhaust bolts. It sounds like you have an exhaust leak. I had this happen. it would do it when the motor wasnt warm. Then once it warmed up it went away. I guess because the gasket swells up. But eventually it go worse, and it did it all the time.
It also wouldnt hurt for you to take off the valve covers and have a look, and run it real quick, to see if its that. In general I would say most engines will make more noise before they get warmed up. For instance, your lifters need to prime up, and your valvetrain sometimes is noisy at start up because the oil hasnt reallly worked its way up there. So it can be alot of things.
But I would start with the basics. And check all your exhaust bolts on that side of the motor. Then take a look under the valve covers. And also dont rull out the egr system. It is located behind the motor, and is connected to the exhaust system as well.
Hope this helps. Good luck.
Old Aug 8, 2004 | 12:20 PM
Thanks alot for the info i believe it or not was kinda wanting somthing to go wrong with my car because i am so pumped to work on somthing, heres my chance...!
Old Aug 8, 2004 | 02:04 PM
Bud M's Avatar
Check for a loose spark plug too.
Nayr
Mar 3, 2023 08:34 PM
RUENUF
Mar 13, 2016 03:37 PM
autoxr166
Sep 25, 2015 04:21 PM
tdigger9899
Sep 7, 2015 10:56 AM
rideordie
Sep 7, 2015 08:22 AM
