Strange sound after Hooker cat-back install.
Old May 4, 2003 | 02:00 AM
StephenF04's Avatar
I dismissed this for quite some time thinking it would go away. It hasn't. There is a very unique sound that comes at idle and just normal driving SOMETIMES. It doesn't do it all the time, it comes from I would say by just ear from right under the console area. I only got a cat back so I don't know that it's that. But at the same time it didn't do it until the cat-back was put on. Any ideas??? Any one have the same thing happen to there's after cat-back install?
Thanks guys,
Stephen
Old May 4, 2003 | 03:34 AM
Twice The Fun's Avatar
What kinda sound????
Old May 4, 2003 | 05:19 AM
joeSS97's Avatar
Check the pipe over the axle,its probably hitting the panhard bar.
Old May 4, 2003 | 09:10 AM
johnpsz's Avatar
A lot of the time our cars have a lot of vibration. Could you be hearing a vibration sound, is it a rattle or maybe banging sounds? Like said above tell us what kind of sound your hearing?
Old May 4, 2003 | 09:31 AM
StephenF04's Avatar
Hmmm...it's not a clanking or banging, the sound occurs too rapidly if that makes since. I actually went through the console dept. to see if there was something in there, it's coming from right under the console area. It's definitely a unique sound, I don't wanna try to rule anything out...I honestly don't know what kind of sound, other than when it does it, it's very rapid, if it is something hitting something else it's doing it very fast. Does that help at all???
Old May 4, 2003 | 09:54 AM
SWINGRRR's Avatar
Sounds like you are hearing the pffft, pfffft, pffft of an exhaust leak. Start your car and carefully put you havd about 1" to 2"s from all you connections and try to "feel" the puffs of exhaust on your hands. I just finished my exhaust with Jethot LT's, Mufflex y, and the Hooker. The only complaint I have is the poor fitment of the mufflex.
Old May 4, 2003 | 10:50 AM
KeVMaN's Avatar
mine was hitting underneath the car in the back where the two peices of the body come together. just bent it back a little and it was fine. you're probably just tapping somethin w/ the exhaust
Old May 4, 2003 | 11:05 AM
chasmanz28's Avatar
yeah something is hitting the frame, if you didint have that noise until the install something is rubbing somehwere, just have to find out where, its its hard to do without a lift
Old May 4, 2003 | 11:12 AM
SWINGRRR's Avatar
re
I still think he's got a leak.
Old May 4, 2003 | 01:34 PM
StephenF04's Avatar
Arrow
OK...I think I found out what the sound is coming from. The exhaust is hitting a rather large bracket about 5 inches wide right in the middle of the car. I don't know how to fix that...I guess I'll take it back to David's and get him to fix it. What's that piece called I'm hitting?
Old May 4, 2003 | 01:43 PM
Ernster500's Avatar
Isn't that the tunnel brace? Mine was hitting in the same exact place. The sound seemed like it was coming from directly under the passenger side floor board. They just need to pull the brace down a little and make sure that the pipe is off of it.
Old May 4, 2003 | 02:42 PM
StephenF04's Avatar
Probably what it is...I know mine personally sounds like it's coming from right under the console. So much so when I first heard it I thought something was rattling around in the console . I don't work Tuesday so I hope I can get it fixed then.
Old May 4, 2003 | 09:28 PM
onebadponcho's Avatar
Unbolt the 4 bolts holding it in, put about 3-4 flat washers between the subframe and the brace, bolt the brace back in; that should fix your problem.
Old May 4, 2003 | 09:32 PM
Ernster500's Avatar
That will probably work. Like I said, mine just had to be bent down a little and it worked like a charm...
The other thing I recently did was install an SLP drive shaft saftely loop. It replaces the tunnel brace and bolts right in. Not only is that thing beefy as all hec, but they made it to give the exhaust plenty of room! Maybe too much...that thing hangs LOW!!!
E
Old May 5, 2003 | 03:57 AM
E
A question about the driveshaft safety loop... did you have to remove the driveshaft to install that one or is the loop itself two pieces? I'd like to find one that's two pieces. I don't really need a loop because I hardly ever race, but it probably wouldn't hurt to put something stronger than that flimsy looking factory thing in there.
techstar
Aug 6, 2015 11:20 AM
tomfric
Parts Wanted
Jul 30, 2015 03:01 PM
Devinfoote87
Jul 30, 2015 09:54 AM
GT what?
Jul 14, 2015 10:17 PM
CARiD
Jul 7, 2015 08:19 AM
