Strange problem HELP!!!!!!
Old May 1, 2003 | 07:31 AM
  #46
xxsaint69x's Avatar
switch pcms with some one...car should run fairly good even with a stock program.
marcin
Old May 1, 2003 | 12:27 PM
  #47
ChrisJ325's Avatar
I tried regrounding off the black wire on the MAF, didnt do anything .
I would switch PCMs with someone, but there isnt anyone in my area to switch with
Is it possible that when I blew the fuse I screwed up the PCM somehow??
Old May 1, 2003 | 12:35 PM
  #48
jmd's Avatar
jmd
Doubtful, given the fusing. You got a factory service manual? I'm thinking check all underhood and fuse panel fuses.
Old May 1, 2003 | 12:54 PM
  #49
ChrisJ325's Avatar
Ive got the Haynes manual, but I dont have the factory one... Dont even have the owners manual anymore I brought it in the house to read over something a few months ago and misplaced it
Old May 1, 2003 | 01:09 PM
  #50
ChrisJ325's Avatar
Is it possible a rocker may have come loose somehow causing this to happen Im just scraping for ideas, not really sure what to check..
Old May 1, 2003 | 01:53 PM
  #51
xxsaint69x's Avatar
its normal for the idle to hang high when u drive around and press the clutch in....you can kinda fix it by messing with a IAC vs mph table in LT1Edit. I got mine to drop almost back to 1k when i press the clutch in when i am driving.
Marcin
Old May 1, 2003 | 02:37 PM
  #52
94FlamdS10Blazr's Avatar
Chris I think you need to focus on the computer related problems you are having. You messed up something when the O2 wire smoked and I dont think you lost a rocker at the same time. We need to go back to the computer. Call Brian over at pcmforless.com or Ion over at madz28.com and talk to them about getting a computer sent out. Ion doesnt offer this on his site so I think you gotta ask him about it. might just take a day or so to get it to you.
this would also be a good time to get those performance mods done to the computer you might have been putting off
Old May 1, 2003 | 04:50 PM
  #53
ChrisJ325's Avatar
My computer is tuned for all my mods....
When I replaced the O2s the car quit running rich, now the idle just hangs around 2000 until i stop, then it falls back down. It has no driveability issues anymore other than that, and Ive been told by several people that comes from the cam I have, and that all big cams will "hang" up like that. So I think everything is fixed.. The O2 replacements did solve the problem of it running super rich though
Old May 2, 2003 | 09:50 AM
  #54
mc63's Avatar
Hey Chris,
Glad to hear your problem is solved.
Later,
Michael
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
1996LT1Z28
Apr 22, 2015 07:56 PM
ShwaZedder
Apr 9, 2015 06:33 AM
