Strange or Moser 12 bolts???
Old Feb 12, 2003 | 08:25 PM
LYSFASTZ's Avatar
Which one is the better component for a M6 with 650+rwtq? I am up in the air, you decide?
33 spline axels, 1350 yokes, etc.....
thanks in advance
Old Feb 12, 2003 | 08:29 PM
stik6shift93's Avatar
With that much power I'd go with a moser 9 inch, twelve bolts are strong but are still prone to breaking with that much power espcieally threw a manual trans.
Old Feb 12, 2003 | 08:55 PM
My Strange just loves 800HP. And it was an M6/Street Twin setup before the current TH400 swap.
I also know George Baxter took his Strange 12-bolt up to 950HP before he replaced it with a 9-inch. The Strange was still in excellent shape when he removed it - but he knew he was going well over 1,100HP. Based on the totally "plug-and-play" install on the Strange, the absence of problems like the apparent need to shorten the DS with the Moser, problems with whining gears, axles that don't fit in all the way and require machining of the retainer plates, shims that aren't shipped with the setup, the need to assemble a lot of parts... etc., I strongly recommend the Strange. Been happy with it for 3-1/2 years. Installed in a couple of hours, with absolutely no help, on jackstands in my garage.
HarleyZ28
Oct 5, 2015 06:23 AM
ddr698
Jan 9, 2015 10:05 AM
kev93z28
Aug 19, 2002 12:48 AM
Speeds8erM-1
Jul 18, 2002 11:36 PM
