Strange metallic sound prior to and during starting
Old Jul 9, 2004 | 06:50 PM
Camaro94Lover's Avatar
Question Strange metallic sound prior to and during starting
I am currently having what I believe is a starter problem because during cranking, the starter makes a grinding sound, similar to when you turn the key with the engine already running. It is also a weak start with irregular cranking. The other problem is when I turn my key to the first position (run), i can hear the fuel pump hum, then stop, which is normal but at the end of it I can hear three metallic clanking sounds which is not normal. Would this be because of the starter as a result of the starter or selonoid engergizing?
Old Jul 16, 2004 | 11:58 AM
Any ideas?
Old Jul 16, 2004 | 12:49 PM
GetaZforgetGT's Avatar
Your solenoid may be hanging up.
Unfortunately, I've never heard of anyone selling the solenoid seperately so you'll have to get a starter.
I would jack the car up and secure it on stands. Have a buddy attempt to start it. Take a hammer and tap the solenoid with the handle. If it stops it is probably the solenoid haning up.
Old Jul 16, 2004 | 12:53 PM
Loadre's Avatar
I shop local to me that does internet business replaced my solenoid for $32.
http://web.camaross.com/forums/showt...hlight=starter
Scroll down to the bottom of that thread.
Old Jul 16, 2004 | 01:12 PM
Very good to know.
Just wish I had that info about a year ago when I had the solenoid go on my starter.
karnykamaro
Feb 2, 2015 01:37 PM
Collector Car
Jan 5, 2015 10:58 AM
squarehead
Nov 21, 2014 08:02 PM
teedoff59
Aug 8, 2002 01:36 AM
