Strange cooling problem!
Just wondering if anyone has had symptoms similar to what I am experiencing. The car (97Z) is pushing coolant into the overflow reservoir but only once in a while. The cap has been replaced and tested and the car runs good, no coolant in the oil and fans seem to be operating normally...both come on about when they should. The only thing left that I can think of is the dreaded head gasket but it seems like if it was bad enough to leak compression into the cooling system it would be bad enough to leak coolant into the oil when shut down. Have not done compression test yet (engine still hot as I type) or a leak down test. The car runs cool when driving but does climb when stopped in traffic just as it always has until the fans kick in and they pull it right back down. Guess I just want someone to tell me it isn't a head gasket.
Re: Strange cooling problem!
Sorry, a head gasket can blow in many different directions. Leaking air or as you said "compression" into the water jacket without leaking water into the oil is very common. The best way to tell is with a leakdown test as you mentioned. The compression test may be a waste of time. The other test that is helpful is pressurizing the coolant system. Had you done any work to the coolant system lately? Maybe trapped air pushing the coolant out? Sorry, best I could to get your hopes up.
at my shop we have a suction bottle that you put on the top of your radiator. theres a blue colored chemical in it and if theres exhaust gases present in your radiator/coolant it turns to a yellow/green color. this is how i diagnosed my head gasket problem. (i didnt have any coolant in my oil either)
sry for not so good news hope its not a head gasket.
Originally Posted by GreenDemon
Are you saying that coolant is overflowing out of the reservoir?
Or that coolant is there?
did you try bleeding the cooling system?? my 97 was doing that also until i took all the coolant out put new stuff in and bleed the system and no problems at all, It also did it when the car was running hot are you over heating??
In my experience, these radiators plug up easily. When I bought my car it doing same symptoms, so i had the radiator rodded out. that fixed it for about a year, then the problems came back, so I just bought a new radiator, now all cooling probelms gone for over 2 years. Imagine if your radiator was about 2/3 the size it should be, thats about how your symtoms act.
speaking from a personal experiance on a truck i had the same thing happen, replaced the cap with a motorad brand or what ever all the chains carry got worse. Finally stopped by a GM dealer and bought a factory cap for about $8 problem solved.
Well here's the latest. When I first noticed this problem (pushing coolant into the overflow) I changed the radiator cap and it didn't do again it for a few days. At the same time I changed the cap I also removed and cleaned the throttle body hoping to improve my idle a bit. A few days later it pushed coolant out again and also was idling worse than before...rough but steady...leading me to believe I might have a head gasket problem. I went ahead and replaced the radiator on a Wednesday and was waiting for the weekend to do a leakdown test to verify a headgasket problem. By Saturday, the car had not only given me no more problems with the cooling system but the rough idle had also disappeared so I just left it alone. It is now almost a week later and still running good and no additional cooling problems.
Now for a follow up question. Is it possible that by removing and cleaning a very dirty idle air control valve that I made the idle worse until the valve either seated itself better or the car "learned" the new idle air conditions? I'm thinking that the radiator cured the cooling problem and the idle smoothed out for one of the reasons mentioned above. Any thoughts?
My Car Did This Out Of The Blue Also. One Day I Just Parked And I Heard A Rumbling In The Front And Next Thing I Knew I Was Overheating Sometimes And Filling The Car Up With Coolant Until One Day I Bleeded The System (about 1/2 An Hour) And Got All The
Air Out And It Was Good To Go! Hopefully This Is Your Problem Too And Not Anything Worse!
Magenta_Hearts
Mar 25, 2015 10:24 AM
