stoker vs. bigger cam
Those are PLENTY good to work on a 383. Those are some impressive exhaust ports! Get a custom grind from Brett and go with that. I'm running a set of LPE 192's with a stock intake and if I can get the dang 60 down, I should run in the 10.3X's. My heads flowed slightly better on the intake and slightly lower on the exhaust compared to your heads. For best all around power though, you can't beat a 383. It's an instant 30 - 40 lbs. ft. of torque.
what are your flow numbers? your compression? your trans? thant n/a right? what size tire? what stall? what headers? what exhaust? whats the weight and what are you running for suspension?
NewsBot
Jan 29, 2015 07:10 PM
NewsBot
Jan 11, 2015 06:10 PM
NewsBot
Dec 28, 2014 06:20 PM
