Stock Z with like 10 MPG
Old Oct 19, 2003 | 11:36 PM
Arbie95Z's Avatar
I bought my car about 2 months ago, and ever since i got it it goes through gas like there's no tomorrow. It had the bottle before I got it. Could it be something in the computer, Fuel pressure changed, or bad O2 sensors.
Old Oct 19, 2003 | 11:40 PM
RamAir95TA's Avatar
O2s, plugs, wires, fuel pressure regulator, exhaust leaks, bad opti/coil, clogged cat, bad fuel, or a combination of all of them, could cause poor gas mileage.
Old Oct 20, 2003 | 03:37 PM
Z28SORR's Avatar
I resently check my 97 it was at 11.16 mpg. I did plugs and wirers and had Chevy reflash the PCM to stock, just in case. The car is stock. Went to 13.00mpg.
Old Oct 20, 2003 | 06:03 PM
Terran2k's Avatar
must be something up with 97s, as my mileage is hovering around 10mpg with a tune up.
Old Oct 20, 2003 | 10:30 PM
Camaro_Guru16NY's Avatar
I would definately try a tune as I think it would help the most but it could be any number of things as Ramair95TA stated. Just start somewhere and see what helps.
good luck,
-JOhn
Old Oct 20, 2003 | 10:42 PM
FacelessZ's Avatar
it could be a clogged cat...clogged fuel filter...bad wires...a large host of things...
Old Oct 20, 2003 | 11:40 PM
You need some scan data from a test drive. That should give ideas on what is going on.
Old Oct 20, 2003 | 11:41 PM
Aeromaks's Avatar
also try the foot mod, dont step on it all the time. =)
but yeah, get a tune up, and in the fashion of cz28.com....
Its probly the Opti.
Old Oct 20, 2003 | 11:46 PM
NewbieWar's Avatar
can opti cause bad fuel gas mileage... i mean no mater what i do, i drive hard i drive slow its 12, ac on its 12, t-top open i might get 13 for no reason... its 12 no mater what
i think im gonna hit my O2's as soon as i can afford the SOB's 60$ each :'(... thats what credit cards are for
Old Oct 21, 2003 | 12:11 AM
Aeromaks's Avatar
i would check o2's and possibly the cat if it is clogged up
Old Oct 21, 2003 | 02:41 AM
MentalCaseOne's Avatar
Through careful Testing I discovered that My IAT sensor would have erratic readings when the engine was warmed up, yet when the engine was at ambient temp it would test just fine.
I had 12mpg at times and other times close to 13.8mpg. never the same. I finally replaced the IAT and it has been consistenty at 13.5MPG ever since then, I am satisfied with the results. One less gremlin to take care of.
Point being is that in your case it could be a combination of problems. I am sure there is something else in my car that will increase that MPG to at least 16mpg average.
Marvin
Old Oct 21, 2003 | 05:41 AM
magius231's Avatar
13.5?? Guys I'm getting around 20MPG on mine with 75% highway driving...if you can't pull 17 or 18 around town theres something wrong. On a long highway trip (the best way to measure it) I can pull 27MPG...
Old Oct 21, 2003 | 08:31 AM
TQdrivenws6's Avatar
I would have to say that something isn't right here. I put my foot into it fairly often, and can't ever remember getting below 15mpg and that was at a road course. I would definitely suggest a full tune up as that is just way too low.
Chris
Old Oct 21, 2003 | 01:47 PM
Terran2k's Avatar
tell me about it, new O2s, new plugs, new wires, new fuel filter, new PCV vavle, new oil in everything, new TPS, new MAP, tried different MAF, I just cant figure it out, now not to hi-jack this guy's threat, but here a link to my auto-tap files if u wanna look at it. also posted in the computer tech forum
ftp://file:file@ftp.isnk.net/home/file
Old Oct 23, 2003 | 11:41 AM
LS1_03's Avatar
Sucks to be you Ryan. I like my 94 Z28, I can mash the throttle all day long and still pull 19 mpg.
