Stock valve covers and Magnum RRs
Old Aug 10, 2003 | 08:23 PM
Naegash's Avatar
I've heard the stock covers will work if you "modify them slighttly". What do you have to cut/file? And how much of it? Thanks for any advice!
Old Aug 10, 2003 | 11:26 PM
atljar's Avatar
Take off the valve covers, and flip it upside down. Where the bolt comes in through the top of the cover, there are supports. At the base of the support, the metal flares out a little, making it thicker than the rest of the support. Make little cuts on each support, so that you can take a pair of pliars and straighten out the entire flare, making it inline with the rest of the support. Thats all you have to do. Complicated to explain, but simple to do once you see it. good luck
Old Aug 11, 2003 | 12:28 AM
EviLZ28's Avatar
will this trick work with other rollers rockers as well?
Old Aug 11, 2003 | 12:38 AM
atljar's Avatar
I havent heard of actually having to clearance the stock covers with any other RR. The problem with the Pro Mags are that they have a wide body, and the supports on the cover, wont slide down between the intake and exhuast rockers. We are just narrowing the part that slides between the rockers so that it fits without hitting.
HectorM52
Jul 30, 2017 11:46 AM
Roadie
Feb 16, 2015 10:34 AM
HectorM52
Jan 30, 2015 11:34 PM
BIGCOWL-IMP
Dec 19, 2014 06:59 AM
thenewkid
Nov 29, 2014 04:54 PM
