Stock Timming Chain?
Old Jan 30, 2005 | 03:30 PM
"White Knight"'s Avatar
What are the part numbers for the timming chain parts for a 94 LT1 Camaro?
Which parts do you think i should replace? I am installing an electric water pump this summer and figure if it's not too much i might put a new chaing and maybe gears in there.
Do you think i should replace it or will it still be good at 130,000 miles? What will i need to replace? Just the chain or the gears too? Or should i just wait and see what i need when i take it off.
Old Jan 30, 2005 | 03:39 PM
96m6lt1's Avatar
Re: Stock Timming Chain?
with that type of mileage your chain is pretty much ready to be retired,since you are going to run an electric h2o pump,get a cloyes chain and call it good,you will regret reusing an old chain....
Old Jan 30, 2005 | 04:35 PM
You can find part numbers on my part numbers page.
With your miles, change the whole set. Even though you are going with an electric pump you can't use a Cloyes set without doing the whole vented opti swap.
Old Jan 30, 2005 | 11:14 PM
Yea i am just staying with the stocker, cause i don't want to convert it over right now. Thanks shoebox.
Old Feb 1, 2005 | 04:05 PM
I do have an extra one that came on a shortblock i bought off someone....the block had thrown a rod--I think at relatively low miles, but it had sat out a while i believe.....how would you go about checking if it's any good.....not that i am going to use it, but just so i know.
Old Feb 1, 2005 | 06:47 PM
IMO, you don't check it. You throw it away.
Old Feb 1, 2005 | 06:49 PM
Pasky's Avatar
Yea, their that cheap.
Old Feb 1, 2005 | 11:06 PM
cheapest place i find them at is GM parts direct and it's about 75bucks. for everything.....crank gear, cam gear, chain. Or will the two gears be okay to use--I assume they wear also....in which case 70 some bucks isn't too cheap IMO--expecially for what you are getting.
Old Feb 2, 2005 | 03:33 AM
MEAN LT1's Avatar
OR you could just a regular sbc timing chain. Why pay all that money when you dont have too.
Old Feb 2, 2005 | 07:19 AM
It may be the same chain as an SBC, but he can't use an SBC cam gear.
Old Feb 2, 2005 | 07:23 AM
I already recommended changing the whole set. It's cheap, considering the consequences when it fails. The gears will have wear. Throwing a new chain on worn gears is not my idea of doing it right.
Old Feb 2, 2005 | 10:44 AM
stupid unvented opti's
Old Feb 2, 2005 | 11:37 AM
disco192's Avatar
ive got a stocker with 40k miles for 10 bucks if youre intereted.
If you are gonna do a cam swap anytime soon, I would definately convert. You can sell the old opti for some decent cash and it will only hit you a little bit.
Old Feb 2, 2005 | 07:49 PM
Bersaglieri's Avatar
But they fail so much quicker than vented!
Maybe try a Lunati Kit? Althought I havent heard much about them here.
-Dustin-
Old Feb 2, 2005 | 11:17 PM
True that.
well first off i have a chain with low miles as stated in my earlier posts. Second this opti developed a high miss and would hate to sell to someone. Third...i do plan on doing a cam swap soon....but even if i did, it wouldn't be anything to large...since it's got 130,000 miles-so it's not worth switching right now.
They just had to make splines in that gear didn't they
Yea about that Lunati kit........went up $100 in summit from their last magazine....and i was considering it, since it uses a billet gear...but am not paying 200 for a set, they can keep that junk for 200 bucks. A friend of mine could make a billet gear for me......that is if i supply the billet.
