stock tb size?
Old May 8, 2007 | 12:26 PM
red_warrior_z28's Avatar
stock tb size?
i just want to make sure im correct. stock throttlebodys are 48mm, correct?
if i stepped up to a 52mm or 54mm what modifcations would need to be done to the intake or will they bolt right up? also how much power if any will be gained over stock tb, with all the bolt-ons and a cc305?
Old May 8, 2007 | 12:32 PM
Mortify's Avatar
It will bolt right up but you will need to use the gasket as a template to make the bores on the intake larger.
Old May 8, 2007 | 01:33 PM
95LT1conv's Avatar
only for a 58mm. gains will most likely be minimal at best
Old May 8, 2007 | 01:43 PM
Mortify's Avatar
So stock bores are 52-54mm?
Old May 8, 2007 | 01:46 PM
bingo's Avatar
Stock throttlebody is 48mm. I believe a 54 will bolt up with no modifications. I know a 52 will. I have one on my car.
Old May 8, 2007 | 04:00 PM
2000GTP's Avatar
You can go up to a 52mm TB, anything larger and you will have to port the intake manifold bores. With your mods, I don't see you needing anything larger then a 52mm though.
Old May 8, 2007 | 04:31 PM
Old May 8, 2007 | 04:48 PM
Wild1's Avatar
Most people won't notice the change without programming. It really depends on your entire package from the engine, exhaust, and intake. It sounds like you have a fair amount of bolt-ons so you may get about 370 RWHP without porting the heads... which would bring it up to 410 RWHP. These are estimates.
Old May 8, 2007 | 09:31 PM
CANTONRACER's Avatar
And way off estimates.
Your stock TB is fine.
Old May 8, 2007 | 10:04 PM
Wild1's Avatar
How are those estimates way off. With all of his bolt ons plus a CC305, he could get 375 RWHP with a larger TB and programing... easy.
Old May 9, 2007 | 02:24 AM
porksoda's Avatar
I hope your talking about flywheel HP becaus those number are WAY off!
Old May 9, 2007 | 02:30 AM
Pyrodawg's Avatar
yea man cmon were talking about an LT1 he'll get around 330-350 at most probably nowhere near the higher
Old May 9, 2007 | 07:50 AM
Wait...did one guy not long ago get pretty good power out of a 305 cam setup....must mean everyone is going to now....gotta love the internet.
HectorM52
Jul 30, 2017 11:46 AM
canbaufo
May 25, 2015 12:01 PM
MyShibbyZ28
Feb 14, 2015 12:05 PM
Brandon Wittmer
Dec 20, 2014 09:51 PM
