stock tb size?
stock tb size?
i just want to make sure im correct. stock throttlebodys are 48mm, correct?
if i stepped up to a 52mm or 54mm what modifcations would need to be done to the intake or will they bolt right up? also how much power if any will be gained over stock tb, with all the bolt-ons and a cc305?
Most people won't notice the change without programming. It really depends on your entire package from the engine, exhaust, and intake. It sounds like you have a fair amount of bolt-ons so you may get about 370 RWHP without porting the heads... which would bring it up to 410 RWHP. These are estimates.
Brandon Wittmer
Dec 20, 2014 09:51 PM
