Stock TB flow?? Why upgrade?
I remember seeing a discussion on this same subject that went on for about four pages a while back. I can't remember the exact numbers that you are wanting but I do know that it was decided that unless you are very heavily modded then it wouldn't make a difference anyways. It is better to spend your 2 or 300 dollors on something worth it, like headers, RR, something. I thought about the same thing some time ago. You can probably do a search and find a discussion or two on it.
Just my .2
Later
Just my .2
Later
Originally posted by $hawn
Two 48mm blades, is 96mm, thats a lot bigger than an ls1 tb, and they do fine with a stock one for awhile, it wouldnt be worth it for 3-400$
I don’t know how big the single bore LS1 tb, but a single bore that is sqrt(4608) = 68mm will flow the same as stock LT1.
It doesn't work like this, the relation is not linear. It goes like this: 48 * 48 * 2 = 4608.
There was a post about this a while ago. I still don't know whether it's worth it to fork out the 300+ for one.
Here's a link about it. http://web.camaross.com/forums/showt...&highlight=CFM
10-31-2016 11:09 AM
