Stock or Stall??
Old Jul 2, 2004 | 09:49 PM
5.7LT1Formula's Avatar
Question Stock or Stall??
almost complete with my rebuild and before i put my trans in i wanted to get your opinions on where or not i should use my stock converter that has low miles on it or buy a stall converter 2000rpm or somethin'
it will be a 383 but not to big of a cam, if i have a stock converter will my car stumble and hesitate when it is put into drive? The car will be a daily driver in the summer and only go to the track 2 or 3 times a year.
Thanks for your input!
Old Jul 2, 2004 | 09:51 PM
jeremyferguson's Avatar
If your gonna spend 500-700.00 on a good converter, I wouldn't go below a 3,000 stall. 2,000 is pretty close to stock as far as I know.
Old Jul 2, 2004 | 09:57 PM
will i be safe with stock though or will it run like crap and bog every time i take off in 1st gear?...
Old Jul 3, 2004 | 05:30 AM
sssalah's Avatar
If its a 383 and you'll have a small cam in there with tuning then the stock should be OK. It mainly depends on the cam size, on my B car I still have the stock stall and with the little 227 cam it drives like stock, when I had the 350 on the camaro it had a hot cam but it was a nightmare with stock stall and tuning.
Old Jul 3, 2004 | 08:54 AM
GREAT... i have a zz9 cam and i think the specs on it are alittle bit bigger than the Hot cam... What RPM range of stall do you guys suggest?
Thanks!
DirtyDaveW
Dec 1, 2016 05:37 PM
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
canbaufo
May 25, 2015 12:01 PM
MyShibbyZ28
Feb 14, 2015 12:05 PM
