stock routing plug wires...
Hey I keep having a problem w/ my #7 cylinder (i think) spark plug wire, the one all the way in the back on the passenger side. It keeps getting torn by the belt. I just got some zip ties, where or what should i zip tie these damn things to so i dont have to change plug wires every time i go to the track?
thanks
thanks
Re: stock routing plug wires...
so no one has any advice on how to route my plug wires? Where they go under the power steering pump is where I am having problems, they are getting too far off the power steering pump and are getting cut by the belt, I have zip ties just no clue what to do to fix this... thanks
If you run them in the stock looms, there should not be a problem. The one you refer to is #8.
wow, thanks shoebox, I do not have that loom right there behidn that belt, which is why my plug wires are being frayed by the belt... could I buy just that loom or use the one from the driver side since it isnt needed as much as that one?
The straight loom is GM PART # 10223670 .
