Stock Rockers On These Heads?
Old Feb 20, 2006 | 02:07 PM
calcm27's Avatar
Will stock LT1 rockers work on these heads? Trick Flow 30400003 1.46 dual springs
Old Feb 20, 2006 | 02:21 PM
Javier97Z28's Avatar
Moderator
Re: Stock Rockers On These Heads?
Are you using these heads on an LT1? Can't tell by your sig what it's going on engine-wise.
If so, wrong part #
TFS-30400010 assembled for LT1
TFS-3042B010 bare for LT1
As far as reusing the rockers.. 'eh.. I'm not sure what size stud is on the assembled trick-flows. Stock is 3/8"
Old Feb 20, 2006 | 02:24 PM
Guest47904's Avatar
Guest
Wow what a question. Why would you use non roller type rockers on a $1200.00 set of heads that won't work on a Gen II block anyway.
As far as the stud size, they are the same but that's only a small part of the equation. You have to be concerned with spring height, diameter, etc.....
Old Feb 20, 2006 | 02:43 PM
calcm27's Avatar
I want to use the LT1 rockers I have on those heads that are on my Gen I roller block with roller cam. 3/8 studs with guidplates.
Valve Spring Pocket Diameter:
1.615"
Valve Spring Cups:
1.48"
1.460" o.d. double with damper
125 lbs. @ 1.780" installed height
376 lbs. @ 1.180" open
420 lbs. per inch rate
.600" maximum valve lift
thats all the info I could find
Old Feb 20, 2006 | 02:58 PM
Guest47904's Avatar
Guest
Still same question, why? Why wouldn't you buy good roller rockers to use on high $ heads atop a high dollar SB?
Old Feb 20, 2006 | 03:07 PM
calcm27's Avatar
Dont have any money, and dont trust the cheap roller tips I have on now. If they fit, I will use them. Not everyone can spend top dollar on parts. I got the heads used for $800
Old Feb 20, 2006 | 08:49 PM
calcm27's Avatar
just need a simple yes or no from someone who knows
HectorM52
Jul 30, 2017 11:46 AM
oldschool
Feb 9, 2016 09:21 PM
Roadie
Feb 16, 2015 10:34 AM
BIGCOWL-IMP
Dec 19, 2014 06:59 AM
thenewkid
Nov 27, 2014 09:41 AM
