Stock Rockers
Old Feb 29, 2004 | 05:47 PM
Spinner's Avatar
Stock Rockers
What's the proper procedure for tightening the stock rocker arms? I'll have to make do with them for two weeks after the cam install. Anyone? (Comp R lifters)
Old Feb 29, 2004 | 06:09 PM
Erik96z's Avatar
I just did this recently, the Chilton's manual said 1/4 turn past zero lash.
Old Feb 29, 2004 | 06:11 PM
Spinner's Avatar
Thats what I figured. Didnt know if the stock arm procedure was any different then with roller rockers
FastWhiteTA's Avatar
Just did it yesterday...Haynes guide book says do 3/4 turn once all the vertical movement is taken up in the pushrods. Make sure it is as TDC for each valve that you do, otherwise it will be screwed up. Good luck.
Old Feb 29, 2004 | 07:23 PM
Spinner's Avatar
I know how to do it, just wasn't sure if the lash was set any different then with RRs
Old Feb 29, 2004 | 07:38 PM
97WRAITH's Avatar
Spinner you can do it while the car is running also.1/4 turn after they stop clacking.That's how I did mine.Just bought some 1.6 pro mags and going to do them the same way.
Rob.
HectorM52
Jul 30, 2017 11:46 AM
oldschool
Feb 9, 2016 09:21 PM
canbaufo
May 25, 2015 12:01 PM
DirtyDaveW
Mar 15, 2015 07:01 PM
MyShibbyZ28
Feb 14, 2015 12:05 PM
