Stock rebuilds?
Old Feb 19, 2006 | 03:01 AM
MeanGreen97Z's Avatar
Stock rebuilds?
My plans require no high RPM rev range. I planned on replacing the rings and bearings and a high volume oil pump. I want to use all high grade fasteners so I can see 6200 RPM at the most. Think I can reuse the stock crank, rods, and pistons? I'm going to have the block honed and and cleaned. Never redone the bottom end of a motor before. What all should I have done and normally what does it cost at a good shop for the basics?
Old Feb 19, 2006 | 11:49 AM
96capricemgr's Avatar
Re: Stock rebuilds?
Why are you looking to mess with it atall?
Old Feb 20, 2006 | 07:12 AM
limige's Avatar
Re: Stock rebuilds?
you know thats essentially what i did and it costed me more than first expected, here's what i did.
had new cam bearings installed and cam installed (xe 230/236) $50?
arp rod bolts and recondition caps $200
main and rod bearings $50
rings $100 if i remember right.....they are metrics so they're more than most
gasket kit $150
elec water pump $115
timing set $75
cam $270
valve job $175
vavle springs and assembly $160-200?
headers $300
that's pretty much the basics, for what i spent it's almost worth AT LEAST changing the pistons to a speed pro forged press fit. but with the money spent redoing the rods it's almost worth buying new rods as well..
it's up to you but in hindsight i'd replace the rods/pistons.
imo
mike
Old Feb 21, 2006 | 11:54 AM
Re: Stock rebuilds?
Im going to put in an LE1 set up and while im at it go ahead and rebuild the bottom end. I just wanna budget overhaul. New rings, seals, and bearings. Going to cost me an assload?
Old Feb 23, 2006 | 01:43 PM
Re: Stock rebuilds?
No opinions?
Old Feb 23, 2006 | 01:54 PM
camarolover20's Avatar
Re: Stock rebuilds?
I been thinkin of the summit rebuild kit.550 bucs and knocks alot of the stuff out of the way.Oil pump ,gaskets ,bearings,pistoins.
Old Feb 24, 2006 | 05:42 AM
Re: Stock rebuilds?
Ya I heard the pistons are a little heavy though...... and for what it costs to recondition the rods....we might as well buy new ones..... wtf. LOL
Old Mar 1, 2006 | 06:09 PM
nfa's Avatar
nfa
Re: Stock rebuilds?
get the eagle sir rods - they come with the arp rod bolts and wont be much more than the cost of equivalent bolts and the cost of reconditioning the stock rods.
canbaufo
May 25, 2015 12:01 PM
MyShibbyZ28
Feb 14, 2015 12:05 PM
importkiller94
Jan 17, 2015 09:03 PM
Brandon Wittmer
Dec 20, 2014 09:51 PM
