Stock rearend whinning
Old Mar 12, 2005 | 04:11 PM
95Zdroptop's Avatar
Just a few days ago my rearend starting whinning. I know if you take gears out they make noise when put them back in, but the only work down to the rearend in 4 years is the pinion seal so the gears would have stayed in place rightt. This was done about 4 months ago since it was leaking. Would the fluid back there just be low or are the gears going out. The car is a 95 with 110k on it. And about how long can I drive it like this.
Old Mar 12, 2005 | 04:13 PM
Joe Bellman's Avatar
Re: Stock rearend whinning
You really should pull the back cover off and look at the gears. Keep the oil that comes out and look for metal pieces or shavings. If you can't see any damage, put fresh oil back in and see what happens.
canbaufo
May 25, 2015 12:01 PM
MyShibbyZ28
Feb 14, 2015 12:05 PM
89 iroc zl1
3rd Gen / L98 Engine Tech
Jan 14, 2015 02:18 AM
ddr698
Jan 9, 2015 10:05 AM
Speeds8erM-1
Jul 28, 2002 06:18 PM
