stock oil pump fine for a rebuild
Old Mar 3, 2009 | 09:57 AM
udlose94z28's Avatar
Im in the process of rebuilding the lt1 and tryin to cut back on as much as i can would it be ok to put the stock oil pump back up there (cc503 cam new valvetrain) or maybe with the white spring or just get another one
Old Mar 3, 2009 | 10:20 AM
a4z28's Avatar
I wouldnt use it its not worth it. You can get a new pump and pickup for about 50 dollars.
Old Mar 3, 2009 | 10:38 AM
RamAir95TA's Avatar
If you have the funds it wouldn't hurt to pick up a new one.
Then again, if you have relatively low miles on your stocker (under 100k), I wouldn't hesitate to put it back on.
Old Mar 8, 2009 | 11:37 PM
marshall93z's Avatar
They're pretty cheap.
Old Mar 8, 2009 | 11:42 PM
87bandit's Avatar
I think I got mine for around 30-40 for pump and pickup
it's a decent amount of added insurance depending on why you have to rebuild, you never know what's still inside it
Old Mar 8, 2009 | 11:58 PM
MachinistOne's Avatar
Take it apart and clean it, put the HP spring in and use it if you want. If it was pumping fine before and you need to save some $$ it will be just fine after you clean it out.
Old Mar 9, 2009 | 06:40 AM
96capricemgr's Avatar
That would have been one of the pumps that are being made cheaply with thin castings. Probably would have been further ahead to keep the stocker.
"New" does NOT equal better, have to figure GM put the stock pump in with a few hundred thousand mile target service life, the aftermarket does not aim that high.
Old Mar 9, 2009 | 06:46 AM
rskrause's Avatar
Moderator
I've reused oil pumps.
Rich
HectorM52
Jul 30, 2017 11:46 AM
HectorM52
Parts Wanted
Jan 10, 2015 09:01 PM
BIGCOWL-IMP
Dec 19, 2014 06:59 AM
craigffb
Sep 5, 2002 08:17 PM
