Stock Motor Pics w/ M6
Old Apr 17, 2008 | 08:53 PM
maverickmk's Avatar
I'm in the process of piecing together a 1996 Z28 with an M6 trans. In the picture below I placed what I think is part of the cruise control system where I think it should bolt when the manifold is in place. Is this the correct positioning? If anyone has a Z28 with an M6 and could take some pictures of under the hood for me I would appreciate it. Thanks.
Old Apr 17, 2008 | 09:10 PM
jclark311's Avatar
I dont believe that is part of the cruise control, its part of the Automatic traction control, if you want PM me with your email address, my brother has a 96 Formula with that setup, i will take pix, and send them to you!
Old Apr 17, 2008 | 09:24 PM
maverickmk's Avatar
that makes much more sense, I sent my email, thanks
Old Apr 17, 2008 | 11:10 PM
Pics I have seen show it over the center of the valve cover.
Old Apr 17, 2008 | 11:21 PM
White96Z28's Avatar
That is over the center of the valve cover. Right in between the intake runners...
Old Apr 17, 2008 | 11:38 PM
hotrod18_69's Avatar
I have removed mine already. But thats the Traction Control box. It does mount on two of the intake manifold bolts and a third one that bolts to the exhuast manifold bolt which from your pic i don't think you have. But here a a few pics on how it mounts.
Old Apr 17, 2008 | 11:47 PM
GreasyB's Avatar
You need that for the throttle cable too. So dont get rid of it unless you get a new throttle cable that goes strait to the tb.
Old Apr 17, 2008 | 11:51 PM
Yes i forgot to mention that. If you would like to remove it. Here is a good write up.
http://www.pharmacy.arizona.edu/staf...eadjuster.html
Old Apr 18, 2008 | 06:03 AM
maverickmk's Avatar
that's great, that was my next question, thanks guys
Old Apr 18, 2008 | 10:17 PM
jclark311's Avatar
I take it you wont need my pix tomorrow?
Old Apr 19, 2008 | 06:20 AM
maverickmk's Avatar
no, thanks though, I appreciate it
HectorM52
Jul 30, 2017 11:46 AM
Jlo
Feb 3, 2015 09:41 PM
blac94Z
Jan 22, 2015 11:19 PM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
