Stock lt1 oil pressure
What does your stock bottom end LT1 have for oil pressure?? I think mine has been gone through and has a hi-volume pump or something. I have a couple buddies that have stock LT1's and their pressure is 40-50 when cold and when warm 15-20 at an idle, 30 when driving down the highway.
Mine is 68-72 when cold, 45-50 when warm at an idle, 55-60 while driving down the highway. Im just curious to see which one is abnormal.
Just so you know, pressure will rise if you use a 8-micron oil filter... the more selective the filter, the more restiction it'll have.
Also, thicker oil (say 10W30 or 20W50) will be higher pressure than say 5W30 or 0W20. The differences will be most apparent when cold, but still exist to alesser extent at opperating pressure.
Lastly, an engine with tighter tolerances will be higher pressure than one with loose tolerances (which is why thicker oil is need in such an engine).
High pressure isn't so much a problem as LOW pressure is.
If you want to drop the pressure somewhat, try a thinner oil and a new filter with less filtering (like a 30 micron).
There are oil treatments for highmilage engines that dissolve gunk, but I'd be careful about using such a thing. Oil analysis can tell you much more about the condition of your engine & bearings than oil pressure alone can. Be careful you don't read too much into oil pressure by itself.
I am not concerned about the high oil pressure. Just trying to figure out if this has been gone through basically. Car has 130,000 on it. I had to change the real main and the oil pan gasket, it looked like an aftermarket gasket, so I don't know whats up with it.
I am wanting to do a cam only or heads and cam to it but not sure if I will if it has 130,000 miles on it.
I am not seeing how that is that much of a concern. You build a SBC and put a Melling M55HV in it and it'll have around 75-80 opn start up and about 60 driving down the road. Thats more than what this is and never had a problem.
Doesn't seem to be as big of a deal as if it was low pressure. I just wanted to verify what other stock LT1's had to determine wheather mine had an aftermarket hi volume pump or something which now I think it does.
Also i beleave over filling the oil pan can cause it to run pretty high (atleast in some cars i have seen it jump way high)
also WHAT OIL are you useing? You didnt put gear oil in it like that one guy did you?
Dont they have a after market SPRING that can go in and raise the oil presure?
Gear oil huh
Who does that.... LOLNo I don't know what pump is in it. Bought the car like this. Runs good and like i said it has great pressure. When I put them together I use the Melling Hi Volume oil pump (M55HV). Great pumps.
