Stock LT1 to Mild
Old Mar 30, 2010 | 05:04 PM
95ZVIK84's Avatar
Question Stock LT1 to Mild
I currently own a stock lt1, i was wanting some input on a good combination as far as cam, valve springs and lifter kit i should use, was well as a nice set of rockers should use to upgrade. Im thinkin the LT4 is too minor an upgrade if plan to go higher in the future. CC503, CC305??
Old Mar 30, 2010 | 05:24 PM
craby's Avatar
im using steel compcam pro rockers and wish i woulda went with the compcam lifters. are u planning on porting the heads and intake? i dont know how the guys here like lloyds work at elliotts portworks but i do. had him do my heads and intake plus my pick of his cams for 2k. ive heard good things about the cc305 but dont know from personal experiance. im using the patriot gold springs.
Old Mar 30, 2010 | 09:15 PM
slomarao's Avatar
call any supporting vendor that carries a full fo body line and they will have everything you need.
I would do:
cc503 w/complete valvetrain. (pushrods, lifters, 1.6 rockers, springs, etc)
Longtube headers
exhaust
cold air intake
mail order pcm tune
than some suspension stuff. also drag radials
Old Mar 31, 2010 | 01:36 PM
95ZVIK84's Avatar
Thumbs up
thanx for all the advice its a big help....
MUCH appreciated...
Old Mar 31, 2010 | 01:47 PM
n2ceptor's Avatar
My mild 93Z:
Crane 227 cam
LT4 spring kit
Comp Cam 1.52 roller tip rockers
Old Mar 31, 2010 | 06:38 PM
95zsean's Avatar
I would do:
Longtube headers
exhaust
cold air intake
mail order pcm tune
I agree, for a first upgrade I like my 503, and with a good set of heads it will make lots of power. Have Fun.
Old Mar 31, 2010 | 06:54 PM
95ZVIK84's Avatar
Think I should go with an aftermarket intake as well, something like Edelbrock?...
Or any other suggestions....
Old Mar 31, 2010 | 08:08 PM
camaronutt's Avatar
I wouldn't spend my money on an Edelbrock intake. Don't think there are any gains to be had. Get your intake ported to match the ported heads if you go that route.
Old Apr 1, 2010 | 07:02 PM
95zsean's Avatar
If your doing head work than have the intake done. But stay away form Edelbrock intake, it only looks good, and does NOTHING for HP.
Old Apr 2, 2010 | 07:07 PM
95ZVIK84's Avatar
what would be a great set of 1.6 rocker arms from summit to go with?
Old Apr 2, 2010 | 07:18 PM
Larsv8's Avatar
Comp cams ultra pro mags.
Old Apr 2, 2010 | 07:51 PM
RamAir95TA's Avatar
Porting the stock manifold on a mild cam-only setup is a waste of money.
Porting the heads on a 503 cammed setup is also a waste of money.
So is the Edelbrock manifold on ANY setup.
Old Apr 3, 2010 | 01:23 PM
95zsean's Avatar
[QUOTE=RamAir95TA;6319272]Porting the stock manifold on a mild cam-only setup is a waste of money.
Really! I beg to differ. My car makes 371 RWHP and runs 12's with street tires, and high 11's with DR and still gets 22 MPG!!! I dont think it was a wast of time.
oldschool
Feb 9, 2016 09:21 PM
D1SC383LT4
Jan 1, 2016 01:56 PM
Jason Short
Jan 19, 2015 06:34 PM
Brandon Wittmer
Dec 3, 2014 09:28 PM
