Stock LT1 intake...How Many CFM's
Old Apr 14, 2005 | 09:45 PM
Randy L's Avatar
At redline RPM, just how much CFM is being sucked through the stock LT1 intake?
How about those larger aftermarket ones?
Old Apr 15, 2005 | 09:54 PM
Randy L's Avatar
Re: Stock LT1 intake...How Many CFM's
C'mon...nobody knows?
Old Apr 16, 2005 | 12:30 AM
A stock 350ci LT1, turning 5,800rpm, assuming a 90% volumetric efficiency would be pulling about 525 CFM, or about 290 grams/sec with standard barometer of 29.92"Hg and an air temperature of 60degF, assuming no more than 1"Hg loss in the intake track.
I think the assumption of 90% VE is a little optimistic for a stock engine, but that gets you in the ball park.
What "larger aftermarket intakes" are you talking about? Do you mean the intake manifold, or the intake ducting/filter?
Old Apr 16, 2005 | 03:00 AM
Randy L's Avatar
I've seen a couple of aftermarket 58mm throttle bodies for the LT1. Was thinking that if I did invest in a Granatelli MAF, I should increase the TB since the stock bore could cause a choke point, diminishing the effectiveness of the MAF. I would also bore the intake manifold using the techniques discussed on other posts.
Old Apr 16, 2005 | 05:27 AM
sssalah's Avatar
The stock throttle body which is 48mm is big enough to support most moderate street applications. As for that Granatelli piece, make a search, it's other people experience that says it's more bad than good.
What mods you have in that LT1 by the way?
oldschool
Feb 9, 2016 09:21 PM
D1SC383LT4
Jan 1, 2016 01:56 PM
Jason Short
Jan 19, 2015 06:34 PM
Brandon Wittmer
Dec 3, 2014 09:28 PM
