Stock LT1 Horsepower?
Old Oct 24, 2004 | 09:46 AM
  #16
blackztpi's Avatar
Re: Stock LT1 Horsepower?
on any stock or mild bolt on auto, go with 3.42 gears. those seem to provide the best off the line grunt and higher speed pull. 3.73's are nice, but a bit steep for a mild bolt on car, in an auto anyway.
Old Oct 24, 2004 | 10:19 AM
  #17
Sandman_97Z's Avatar
you have a computer program ???
Old Oct 24, 2004 | 11:11 AM
  #18
ChrisUlrich's Avatar
How much faster in the 1/4 are the 96 WS6's then the 94 GT's? Both M6's assuming good drivers.
They have 3.42's apposed to 2.73 and rated with 20 more hp because of dual cats and ram air baby!! haha
Old Oct 24, 2004 | 11:20 AM
  #19
)2overt SS's Avatar
It's called All-Data. It's just a computer program that lists specs and how two's. It's like Chiltons or Haynes, only on a disk
Old Oct 24, 2004 | 11:32 AM
  #20
But why do you need a computer program to tell you something like factory rated HP? I mean, isnt that sorta common knowledge? I could understand using it to guide you thru rebuilding your motor, but rated HP? It was just funny to me I guess, thats all...
Old Oct 24, 2004 | 11:41 AM
  #21
Sanger's Avatar
Originally Posted by )2overt SS
I've seen the SS model been rated as high as 315 horsepower. Which seems just out of the question.
The '96 SS with standard exhaust came as 305hp. If you ordered the optional 20TL exhaust, it was then bumped up to 315hp.
Old Oct 24, 2004 | 01:08 PM
  #22
emg32's Avatar
Can you guys suggest a good brand and place to buy 3.42 or 3.73 gears? If I change the gears is there anything else I would have to replace or change?
Old Oct 24, 2004 | 02:03 PM
  #23
Yby4n95Z's Avatar
You can go Motive gears to keep the "WHINE" down. Aftermarket rears can whine if not set up correct and some manufactures gears whine a bit more. You will also need something to recalibrate your PCM if you don't want your speedo to read off. I would do a TA Rear Girdle while your at it. It will strengthen the rear end. Both of these can be purchased here:
www.exoticperformanceplus.com
Ask for Bob tell him Adam Carper sent you.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
D1SC383LT4
Jan 1, 2016 01:56 PM
D1SC383LT4
Jan 26, 2015 01:41 PM
Brandon Wittmer
Dec 3, 2014 09:28 PM
